查看: 2281|回复: 3
问:在autocad对象模型中,怎样得到一个图幅的左下角和右上角的坐标(vba)??
发表于 2002-11-20 13:39:00 | 显示全部楼层 |阅读模式
 楼主| 发表于 2002-11-20 13:41:00 | 显示全部楼层
急!!!!!!!!!!!!!!!!!!!ji
发表于 2002-11-20 20:15:00 | 显示全部楼层
获取图幅的左下角和右上角的坐标
可以用Document.Limits来获取,也可以系统变量LIMMAX和LIMMIN。
范例如下:
Sub Example_Limits()
    ' This example finds the current limits for the drawing.
    ' It then changes the limits for the drawing. The grid
    ' is turned on to show the limits.
    ' Turn on the grid for the active viewport
    ThisDrawing.ActiveViewport.GridOn = True
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ' Find the current limits
    Dim currLimits As Variant
    currLimits = ThisDrawing.Limits
    MsgBox "The current drawing limits are " & vbCrLf _
           & "Lower-left corner " & ThisDrawing.Limits(0) & ", " & ThisDrawing.Limits(1) & vbCrLf _
           & "Upper-right corner " & ThisDrawing.Limits(2) & ", " & ThisDrawing.Limits(3), , "Limits Example"
    ' Change the limits
    Dim newLimits(0 To 3) As Double
    newLimits(0) = 2#: newLimits(1) = 2#: newLimits(2) = 4#: newLimits(3) = 4#
    ThisDrawing.Limits = newLimits
    ThisDrawing.Regen acActiveViewport
    MsgBox "The new drawing limits are " & vbCrLf _
    ' Reset the drawing limits
    ThisDrawing.Limits = currLimits
    MsgBox "The drawing limits have been reset to " & vbCrLf _
End Sub
发表于 2002-11-26 18:49:00 | 显示全部楼层
用GetBound函数
用GetBound函数
GMT+8, 2025-6-17 08:23 , Processed in 0.188910 second(s), 24 queries , Gzip On.
