查看: 2445|回复: 2
随机有名块
发表于 2005-3-22 22:37:00 | 显示全部楼层 |阅读模式
随机有名块,匿名块实在不方便! 我想效果要和下面龙龙的匿名块一样快截,先谢谢大家了 ;;建立匿名块
;;by 龙龙仔
(defun C:NONAME_BLK (/ HOLDECHO HOLDBLIP A AA BLKREF)
(command "_.undo" "_group")
(setq HOLDECHO (getvar "cmdecho"))
(setq HOLDBLIP (getvar "blipmode"))
(setvar "cmdecho" 0)
(setvar "blipmode" 0)
(prompt "\n选取对象建立匿名块: ")
(setq AA (ssget))
(setq A (rtos (* (getvar "CDATE") 1E8)))
(if (/= AA NIL)
(command "_.BLOCK" A "0,0" AA "")
(command "_.INSERT" A "@" "" "" "")
(setq BLKREF (vlax-ename->vla-object (entlast)))
(vla-put-name
(vla-item (vla-get-blocks
(vla-get-activedocument (vlax-get-acad-object))
(vla-get-name BLKREF)
"*U"
(vlax-release-object BLKREF)
(alert "\n没有选取任何对象!")
(setvar "blipmode" HOLDBLIP)
(setvar "cmdecho" HOLDECHO)
(command "_.undo" "_end")
发表于 2005-4-7 14:14:00 | 显示全部楼层
拷贝到剪贴板
粘贴为块
发表于 2006-3-10 16:00:00 | 显示全部楼层
 "*U"    ;;;把 *u 删掉就可生成以系统时间命名的块
GMT+8, 2025-5-2 08:07 , Processed in 0.155998 second(s), 24 queries , Gzip On.
