帖子
查看: 2005|回复: 3
能在任何autocad版本開啟任何圖檔的插件
发表于 2005-3-2 10:00:00 | 显示全部楼层 |阅读模式
能在任何版本开启任何图档的插件
(注意:先关闭cad再安装)
Open Any Version of DWG in Any Version of AutoCAD®.
The free DWGgateway plug-in allows you to easily work with multiple versions of DWG files generated by any version of AutoCAD, regardless of the version you currently own.
You can now eliminate the hassle of being forced to upgrade AutoCAD for compatibility reasons only.
Download it now at: http://www.dwggateway.com/.
Great News
You do not have to upgrade your AutoCAD® license to the new version of AutoCAD to be compatible with your DWG files.
DWGgateway
DWGgateway™ is the first free data translation plug-in that enables AutoCAD users to work easily with DWG data generated by any version of AutoCAD.
Save time and money by eliminating the need to buy new software or keep multiple versions of AutoCAD just to be able to share work and collaborate with other AutoCAD users. The free DWGgateway data translation plug-in makes it easy for you to open and work seamlessly with DWG files created with any version of AutoCAD software. By enabling you to easily overcome data compatibility issues with coworkers and external vendors, DWGgateway helps to reduce costs and improve your productivity.
What users are saying
"An excellent option for those who do not want to be forced to constantly upgrade their Autocad. I have both opened and used several Autocad 2004 drawings on 2000i with no problems!."
发表于 2005-3-4 11:10:00 | 显示全部楼层
如何用啊
发表于 2005-3-4 15:55:00 | 显示全部楼层
怎么下载?看不懂
发表于 2012-5-15 11:39:14 | 显示全部楼层
0000000000000000000000000000000000000000
GMT+8, 2025-6-5 05:45 , Processed in 0.165917 second(s), 23 queries , Gzip On.
