楼主: torcky
[原创]比较两多义线图元是否相同
发表于 2005-10-30 00:07:00 | 显示全部楼层
比较两个多义线是否“相同”,包括旋转或者镜像后的
  1. (defun sampl (e1 e2 / getinfo getdis)
  2.   (defun getinfo (lst)
  3.     (vl-remove-if-not
  4.       (function
  5.     (lambda (x) (vl-position (car x) '(39 40 41 42 43)))
  6.       )
  7.       lst
  8.     )
  9.   )
  10.   (defun getdis    (e / n m dl)
  11.     (setq n (fix (vlax-curve-getendparam e))
  12.       m 0.
  13.     )
  14.     (repeat n
  15.       (setq dl (cons (vlax-curve-getdistatparam e m) dl)
  16.         m  (1+ m)
  17.       )
  18.     )
  19.     dl
  20.   )
  21.   (if (and (= (vlax-curve-getendparam e1) (vlax-curve-getendparam e2))
  22.        (= (vlax-curve-isclosed e1) (vlax-curve-isclosed e2))
  23.       )
  24.     (and (equal (getinfo (entget e1)) (getinfo (entget e2)) 1e-10)
  25.      (equal (getdis e1) (getdis e2) 1e-7)
  26.     )
  27.   )
  28. )
发表于 2007-1-18 10:38:00 | 显示全部楼层
GMT+8, 2025-5-25 15:45 , Processed in 0.153281 second(s), 16 queries , Gzip On.
