查看: 4203|回复: 9
诸位:请教一个问题,如何将cad文件输出为PDF文件?
发表于 2005-1-20 10:52:00 | 显示全部楼层 |阅读模式
发表于 2005-1-20 17:21:00 | 显示全部楼层
安装Adobe Acrobat 之后就会出现一台打印机,
在出图时选择这台打印机就行了
发表于 2005-1-20 22:47:00 | 显示全部楼层
安装一个虚拟的PDF打印机,用这个打印机就可以打印成PDF文件。
发表于 2005-1-21 11:09:00 | 显示全部楼层
丘陵发表于2005-1-20 17:21:00安装Adobe Acrobat 之后就会出现一台打印机, 在出图时选择这台打印机就行了
我装的网上下载的5.0中文版,关机重启后打印老出错,每次都要卸载重装才正常打印,还好速度快(我的操作系统是xp+sp2)
发表于 2005-1-22 12:00:00 | 显示全部楼层
这里的高手真多啊
发表于 2005-1-25 09:56:00 | 显示全部楼层
要安装Acrobat,而不是Reader!
 楼主| 发表于 2005-3-14 17:05:00 | 显示全部楼层
[LISP]谢谢!再问,能否把pdf文件转化成cad文件?
发表于 2005-3-14 17:37:00 | 显示全部楼层
不能,就是转过来也是没有利用价值的.
 楼主| 发表于 2005-3-14 17:50:00 | 显示全部楼层
转过来不就能编辑、修改、画图了吗?
发表于 2005-3-14 17:55:00 | 显示全部楼层
http://www.autodwg.com/
Active DWG DXF Converter Active DWG DXF ConverterSupport AutoCAD 2005 Now!
A batch bi-directional DWG and DXF converter and File version converter without need of AutoCAD !
DWG to PDF Converter AutoDWG PDF Converter Support AutoCAD 2005 Now!
AutoDWG PDF Converter allows you convert DWG and DXF files to PDF files directly without need of AutoCAD.
DWG or DXF to BMP, JPG, TIF, GIF, PNG DWG2Image ConverterSupport AutoCAD 2005 Now!
Batch convert DWG or DXF to BMP, JPG, TIF, GIF, PNG without need of AutoCAD !
dwf to dwg converter DWF Importer ( DWF to DWG Converter)
DWF Importer(DWF to DWG Converter) is an AutoCAD AddIn help you import DWF file into AutoCAD, it supports AutoCAD 2005, 2004, 2000/2000i and R14.
DWG DWF DXF Converter Conversion DWG to DWF Converter
AutoDWG DWG DWF Converter a batch converter converts DWG/DXF to DWF without need of AutoCAD. It supports AutoCAD version R9 to latest version AutoCAD 2005. Support AutoCAD 2005 Now!
DWG to Flash, AutoCAD to Flash Converter FlashDWG--DWG to Flash Converter
Flash your AutoCAD DWG files. FlashDWG is a dwg to flash converter, is the best way to share and publish AutoCAD DWG files on the web. FlashDWG is a dwg viewer without need of dwg viewer.
AutoDWG Attribute Extractor AutoDWG Attribute Extractor
AutoDWG Attribute Extractor Help you batch extract attribute data from AutoCAD attribute blocks without need of AutoCAD. It supports most DWG formats including AutoCAD Release 9 through to the present AutoCAD 2005. Support AutoCAD 2005 Now!
AutoDWG eTransmit
With AutoDWG eTransmit, you can easily compress and transmit dwg files -include all associated files and xrefs-as a single information set to anyone with email, no need of AutoCAD.
GMT+8, 2025-5-16 22:29 , Processed in 0.193415 second(s), 24 queries , Gzip On.
