查看: 2827|回复: 2
[ARX]派生于AcDbObject的定制类实体加入到对象字典的问题??
发表于 2005-1-10 00:06:00 | 显示全部楼层 |阅读模式
我自己写了一个类要加入字典中,但调不通,请高手指点。。。 下面是代码: // ScaleClass.h: interface for the CScaleClass class.
////////////////////////////////////////////////////////////////////// #if !defined(AFX_SCALECLASS_H__EA5D03B9_CC89_40B1_8BB4_48EB14A3EF04__INCLUDED_)
#define AFX_SCALECLASS_H__EA5D03B9_CC89_40B1_8BB4_48EB14A3EF04__INCLUDED_ #if _MSC_VER > 1000
#pragma once
#endif // _MSC_VER > 1000 class CScaleClass : public AcDbObject
public:
void setvScale(double vs);
void sethScale(double hs);
void getvScale(double hv);
void gethScale(double hs);
double vScale;
double hScale;
CScaleClass();
virtual ~CScaleClass(); }; #endif // !defined(AFX_SCALECLASS_H__EA5D03B9_CC89_40B1_8BB4_48EB14A3EF04__INCLUDED_)
// ScaleClass.cpp: implementation of the CScaleClass class.
////////////////////////////////////////////////////////////////////// #include "stdafx.h"
#include "resource.h"
#include "ScaleClass.h" #ifdef _DEBUG
#undef THIS_FILE
static char THIS_FILE[]=__FILE__;
#define new DEBUG_NEW
#endif //////////////////////////////////////////////////////////////////////
// Construction/Destruction
////////////////////////////////////////////////////////////////////// CScaleClass::CScaleClass()
CScaleClass::rxInit();
} CScaleClass::~CScaleClass()
{ } void CScaleClass::gethScale(double hs)
hs=hScale;
return;
} void CScaleClass::getvScale(double hv)
hv=vScale;
return;
} void CScaleClass::sethScale(double hs)
hScale=hs;
return;
} void CScaleClass::setvScale(double vs)
vScale=vs;
return;
下面是加入程序 void GeoMapFun::createDictionary(double hs, double vs)
AcDbDictionary *pNamedobj;
acdbHostApplicationServices()->workingDatabase()->
getNamedObjectsDictionary(pNamedobj, AcDb::kForWrite); // Check to see if the dictionary we want to create is
// already present. If not, create it and add
// it to the named object dictionary.
AcDbDictionary *pDict;
if (pNamedobj->getAt("SCALE_DICT", (AcDbObject*&) pDict,
AcDb::kForWrite) == Acad::eKeyNotFound)
pDict = new AcDbDictionary;
AcDbObjectId DictId;
pNamedobj->setAt("ASDK_DICT", pDict, DictId);
pNamedobj->close();
if (pDict) { // Create new objects to add to the new dictionary,
// add them, then close them.
CScaleClass *pObj1 = new CScaleClass();
pObj1->sethScale(hs);
pObj1->setvScale(vs);
AcDbObjectId rId1;
pDict->setAt("OBJ1", pObj1, rId1);
pObj1->close();
pDict->close();
} } void GeoMapFun::iterateDictionary(double hs, double vs)
->getNamedObjectsDictionary(pNamedobj, AcDb::kForRead); // Get a pointer to the ASDK_DICT dictionary.
pNamedobj->getAt("SCALE_DICT", (AcDbObject*&)pDict,
AcDb::kForRead);
pNamedobj->close(); // Get an iterator for the ASDK_DICT dictionary.
AcDbDictionaryIterator* pDictIter= pDict->newIterator();
CScaleClass *pMyCl;
for (; !pDictIter->done(); pDictIter->next()) { // Get the current record, open it for read, and
// print its data.
pDictIter->getObject((AcDbObject*&)pMyCl,
AcDb::kForRead);
pMyCl->gethScale(hs);
pMyCl->getvScale(vs);
pMyCl->close();
acutPrintf("\nintval is: %d", hs);
delete pDictIter;
pDict->close(); } 请高手指点,谢谢!!
发表于 2009-12-15 17:20:00 | 显示全部楼层
我也出现了相同的问题,请问是怎么解决的呢?
发表于 2010-9-17 15:13:00 | 显示全部楼层
顶起,希望在4楼。
GMT+8, 2025-5-1 21:19 , Processed in 0.167348 second(s), 23 queries , Gzip On.
