查看: 2876|回复: 1
CWnd::FromHandle(adsw_acadMainWnd())
发表于 2005-1-8 22:59:00 | 显示全部楼层 |阅读模式
请问用ARX wizard生成ARX工程,用mfc对话框类的时候,生成对话框类的时候怎么要用:
HelloDlg Hellor2000dlg(CWnd::FromHandle(adsw_acadMainWnd()));
为什么呢?可是直接用HelloDlg Hellor2000dlg;也可以一样用啊.可以正常运行。
有什么区别呢?
谢谢!
发表于 2005-1-9 11:48:00 | 显示全部楼层
CWnd::FromHandle的解释是: Returns a pointer to a CWnd object when given a handle to a window.
If a CWnd object is not attached to the handle, a temporary CWnd object
is created and attached.
当为窗口定义句柄时返回一个指针给CWnd对象.如果CWnd对象没有附着句柄,
则临时CWnd对象被创建. CWnd::FromHandle(adsw_acadMainWnd())只是明确指出了所创建的Dialog的父窗体是
AutoCAD Main Frame? 大概就这样吧!
GMT+8, 2025-5-11 02:09 , Processed in 0.173472 second(s), 23 queries , Gzip On.
