查看: 3126|回复: 2
读txt文件并分离出坐标来lisp程序.还不完善还是先发一个也许能帮初学者一个忙.->
发表于 2004-12-10 21:49:00 | 显示全部楼层 |阅读模式
这是一个有关DMC配准前读txt中(见附件)的特定字符串后坐标的小程序,例子中我只提取西南和东北角点的X,Y坐标.我是集合了几个人的思路来写的.还不完善,但对于像我这样的初学者来说可能会帮上一点忙儿.所以就先发上来一个.希望多提宝贵意见. (defun c:DMCpz ( / txt fi start li str_tfh str_blc
str_WSx str_WSy str_ENx str_ENy WS_x WS_y EN_x EN_y
(setq path_txt (getfiled "Select .txt file" "" "txt" 2))
(setq fi (open path_txt "r"))
(setq ;str_tfh ""
str_WSx ""
str_WSy ""
str_ENx ""
str_ENy ""
;str_blc "1:5000"
(setq start T)
(while (and start (setq li (read-line fi)))
(cond
((wcmatch li "*图号*") (setq str_tfh li))
((wcmatch li "*DOM裁切范围西南角点X坐标*") (setq str_WSx li))
((wcmatch li "*DOM裁切范围西南角点Y坐标*") (setq str_WSy li))
((wcmatch li "*DOM裁切范围东北角点X坐标*") (setq str_ENx li))
((wcmatch li "*DOM裁切范围东北角点Y坐标*") (setq str_ENy li)(setq start nil))
(t nil)
(setq WS_x
(atof (substr str_WSx (+ 1 (strlen ":") (vl-string-search ":" str_WSx)))
(setq WS_y
(atof (substr str_WSy (+ 1 (strlen ":") (vl-string-search ":" str_WSy)))
(setq EN_x
(atof (substr str_ENx (+ 1 (strlen ":") (vl-string-search ":" str_ENx)))
(setq EN_y
(atof (substr str_ENy (+ 1 (strlen ":") (vl-string-search ":" str_ENy)))
(command ".line" (list WS_x WS_y) (list EN_x EN_y) "")
(close fi)
参与人数 1金钱 +2 贡献 +2 激情 +2 收起 理由
王咣生 + 2 + 2 + 2 【好评】支持本版块
 楼主| 发表于 2004-12-10 21:51:00 | 显示全部楼层
发表于 2004-12-10 22:09:00 | 显示全部楼层
读取文件,尤其是txt文件,是初学者首先会面对的最实用的课题!
GMT+8, 2025-5-25 08:00 , Processed in 0.144205 second(s), 25 queries , Gzip On.
