- 积分
- 74307
- 明经币
- 个
- 注册时间
- 2001-6-7
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - ;; WSH.LSP Copyright 1999 Tony Tanzillo
- ;; WSH.LSP demonstrates how to use the Windows Scripting
- ;; Host's FileSystemObject in Visual LISP Applications.
- ;; The FileSystemObject is part of Microsoft's Windows
- ;; Scripting Host, which is shipped with Windows 98 and
- ;; Internet Explorer. You can also download and install
- ;; the Windows Scripting Host on any NT4 or Windows 9x
- ;; system by downloading it from Microsoft's web site:
- ;; http://www.microsoft.com/scripting
- ;; The FileSystemObject and its aggregates provide a
- ;; well-defined, high-level ActiveX interface to the
- ;; file system and its contents.
- ;; Within the FileSystemObject, Drives, Folders, and
- ;; Files are all represented by like-named ActiveX
- ;; objects (Folder, File, Drive, and so on). Some of
- ;; those objects expose a collection property that
- ;; provides access to child objects.
- ;; For example, Drive objects have a collection of
- ;; Folder objects. Folder objects have a collection of
- ;; File objects and SubFolder objects. You can use these
- ;; objects and collections to access and process folders
- ;; and files in a hierarchial fashion.
- ;; The following is a short synopsys of the properties
- ;; and methods of the top-level FileSystemObject. The
- ;; aggregate objects within the FileSystemObject (File,
- ;; Folder, Drive, and so forth) are not detailed here.
- ;; You can get complete information on all child objects
- ;; from the Windows Scripting Host documentation.
- ;; Note that the method/property/constant prefix "wsh-"
- ;; is VLISP-specific, as defined by the load-scripting
- ;; function below.
- ;; Windows Scripting Host FileSystemObject
- ;; Properties:
- ;; (wsh-get-Drives)
- ;; Methods:
- ;; (wsh-BuildPath <Path> <Name>)
- ;; (wsh-CopyFile <Source> <Destination> [<Overwrite = :vlax-true>])
- ;; (wsh-CopyFolder <Source> <Destination> [<Overwrite = :vlax-true>])
- ;; (wsh-CreateFolder <FolderName>)
- ;; (wsh-CreateTextFile <FileName> [<Overwrite = :vlax-false> [<Unicode = :vlax-false>]])
- ;; (wsh-DeleteFile <FileName> [<Force = :vlax-false>])
- ;; (wsh-DeleteFolder <FolderName> [<Force = :vlax-false>])
- ;; (wsh-DriveExists <DriveSpec>)
- ;; (wsh-FileExists <FileSpec>)
- ;; (wsh-FolderExists <FolderSpec>)
- ;; (wsh-GetAbsolutePathName <PathSpec>)
- ;; (wsh-GetBaseName <Path>)
- ;; (wsh-GetDrive <DriveSpec>)
- ;; (wsh-GetDriveName <Path>)
- ;; (wsh-GetExtensionName <Path>)
- ;; (wsh-GetFile <FileSpec>)
- ;; (wsh-GetFileName <PathSpec>)
- ;; (wsh-GetFolder <FolderSpec>)
- ;; (wsh-GetParentFolderName <Path>)
- ;; (wsh-GetSpecialFolder <FolderSpec>)
- ;; (wsh-GetTempName)
- ;; (wsh-MoveFile <Source> <Destination>)
- ;; (wsh-MoveFolder <Source> <Destination>)
- ;; (wsh-OpenTextFile <FileName> [<IOMode = :wsh-ForReading> [<Create = :vlax-false>
- ;; [<Format = :wsh-TristateFalse]]])
- ;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Global constants(setq fso:progid "Scripting.FileSystemObject")
- (setq fso:prefix "wsh-");;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; Utility functions
- (defun load-scripting ( / server)
- (if (not wsh-get-drives)
- (progn
- (vl-load-com)
- (setq server (CoGetClassServer fso:progid))
- (if (not server)
- (alert "Error: Windows Scripting Host is not installed")
- (progn
- (vlax-import-type-library
- :tlb-filename Server
- :methods-prefix fso:prefix
- :properties-prefix fso:prefix
- :constants-prefix (strcat ":" fso:prefix)
- )(defun ProgID->CLSID (ProgID)
- (vl-registry-read
- (strcat "HKEY_CLASSES_ROOT\" progid "\\CLSID")
- )(defun CoGetClassProperty (ProgID property / clsid)
- (if (setq clsid (ProgID->CLSID ProgID))
- (vl-registry-read
- (strcat
- "HKEY_CLASSES_ROOT\\CLSID\"
- clsid
- "\" property
- )(defun CoGetClassServer (progid)
- (CoGetClassProperty progid "InprocServer32")
- );; load Windows Scripting Host Type Library(load-scripting) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
- ;; Windows Scripting Host FileSystemObject Example:
- ;; Function (FindFiles <Folder> <Pattern>)
- ;; This function uses the FileSystemObject to
- ;; find all files in a given folder and all
- ;; subfolders that match a specified pattern.
- ;; It returns a list of the full filespec of
- ;; each file that was found, or nil if no files
- ;; were found.
- ;; Note that the pattern argument is a wcmatch-
- ;; style wildcard pattern, rather than a DOS
- ;; wildcard pattern. Hence, if you want to
- ;; include the period extension delimiter in the
- ;; pattern, you must prefix it with ` (backquote).
- ;; Finally, this demonstration code is highly-
- ;; ineffecient, mainly due to the use of (append)
- ;; for constructing the resulting list. If you
- ;; are serious about processing large amounts of
- ;; files, you may want to consider optimizing it.
- ;; Example (find all LISP files in D:\LISP):
- ;; (FindFiles "D:\\LISP" "*`.LSP") ;; Note backquote!!!(defun FindFiles (FolderSpec Pattern / fso Folder rslt Find:OnSubFolder) ;; If the function find-in-folders:onSubFolder is
- ;; defined, it is called and passed each folder
- ;; object that is processed. This function could
- ;; be used to keep a user informed on the progress
- ;; of a long search operation.
- (defun Find:OnSubFolder (Folder)
- (princ
- (strcat
- " \r"
- "Searching " (wsh-get-path folder)
- ) (setq pattern (strcase pattern))
- (setq fso
- (vla-getInterfaceObject
- (vlax-get-acad-object)
- "Scripting.FileSystemObject"
- (setq folder (wsh-GetFolder fso FolderSpec))
- (setq rslt (find-in-folders Folder))
- (vlax-release-object Folder)
- (vlax-release-object fso)
- rslt
- ;; This recursive function processes each
- ;; folder object, and its subfolders.
- (defun find-in-folders (Folder / Files SubFolders result) ;; Process files in this folder:
- (setq Files (wsh-get-files Folder))
- (vlax-for file files
- (if (wcmatch (strcase (wsh-get-name file)) pattern)
- (setq result (cons (wsh-get-path file) result))
- (vlax-release-object file)
- ) (vlax-release-object files)
- ;; Process subfolders in this folder (recursive)
- (setq SubFolders (wsh-get-SubFolders folder))
- (vlax-for SubFolder SubFolders
- (if Find:OnSubFolder
- (Find:OnSubFolder SubFolder)
- (setq result
- (append result
- (find-in-folders Subfolder)))
- (vlax-release-object subfolder)
- (vlax-release-object SubFolders)
- result
- ;;;;;;;;;;;;;;;;;;;;;;;;;;; wsh.lsp ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
