查看: 3282|回复: 7
我转我转我转转转
发表于 2004-11-22 20:29:00 | 显示全部楼层 |阅读模式
程序做什么,谁run谁知道! (defun c:w1 ()
(princ "\n")
(repeat 30 ;控制次数
(princ "*****-- -- -- --*****")
(mydelay )
(princ "\r")
(princ "*****\\\\ \\\\ \\\\ \\\\*****")
(mydelay )
(princ "\r")
(princ "*****|| || || ||*****")
(mydelay )
(princ "\r")
(princ "*****// // // //*****")
(mydelay )
(princ "\r")
(princ "\r")
(princ " ")
(defun mydelay(/ i j sum crtl)
(setq crtl 20) ;控制快慢
(setq i 0)
(setq sum 0)
(while (< i crtl)
(setq i(1+ i))
(setq j 0)
(while(< j 1000)
(setq j(1+ j))
(setq sum (+ sum j))
参与人数 1金钱 +1 贡献 +3 激情 +2 收起 理由
王咣生 + 1 + 3 + 2 【好评】虽然实用价值不高, 但瞒有创意的
发表于 2004-12-25 18:06:00 | 显示全部楼层
;;;这样更直接和简洁明了! (defun c:test ()
(repeat 20 ;控制次数
(_dy)
(princ "\r*****---- ---- ---- ----*****")
(_dy)
(princ "\r*****\\\\\\\\ \\\\\\\\ \\\\\\\\ \\\\\\\\*****")
(_dy)
(princ "\r*****|||| |||| |||| ||||*****")
(_dy)
(princ "\r*****//// //// //// ////*****")
(defun _dy ()
(command "delay" "80") ;控制快慢
发表于 2005-1-8 09:28:00 | 显示全部楼层
上面的程序能不能把这些"*****\\\\\\\\ \\\\\\\\ \\\\\\\\ \\\\\\\\*****"在运行时加入不同的颜色变化,那就更好了.
发表于 2005-2-23 14:12:00 | 显示全部楼层
这样就有点用途了。
发表于 2005-3-6 21:39:00 | 显示全部楼层
可以在图面五光十色地转了:
  1. (load"xyp_lib")
  2. (defun c:test()
  3.    (jzhz)
  4.    (mkla"test"1)
  5.    (setq pt(getpoint"\n点 : "))
  6.    (while T
  7.        (command "text" "j" "MC" pt "500" "0" "*****---- ---- ---- ----*****")
  8.        (setq s1 (entlast))
  9.        (command"zoom""e")
  10.        (_dy)
  11.        (sub_upd s1 1 "*****\\\\\\\\ \\\\\\\\ \\\\\\\\ \\\\\\\\*****")
  12.        (sub_upd s1 62 2)
  13.        (_dy)
  14.        (sub_upd s1 1 "*****|||| |||| |||| ||||*****")
  15.        (sub_upd s1 62 3)
  16.        (_dy)
  17.        (sub_upd s1 1 "*****//// //// //// ////*****")
  18.        (sub_upd s1 62 4)
  19.        (_dy)
  20.        (sub_upd s1 1 "*****---- ---- ---- ----*****")
  21.        (sub_upd s1 62 5)
  22.        (_dy)
  23.        (sub_upd s1 1 "*****\\\\\\\\ \\\\\\\\ \\\\\\\\ \\\\\\\\*****")
  24.        (sub_upd s1 62 6)
  25.        (_dy)
  26.        (sub_upd s1 1 "*****|||| |||| |||| ||||*****")
  27.        (sub_upd s1 62 7)
  28.        (_dy)
  29.        (sub_upd s1 1 "*****//// //// //// ////*****")
  30.        (sub_upd s1 62 8)
  31.        (_dy)
  32.        (sub_upd s1 1 "*****---- ---- ---- ----*****")
  33.        (sub_upd s1 62 9)
  34.        (_dy)
  35.        (entdel s1)
  36.                )
  37.    )
  38. (defun _dy ()
  39.    (command "delay" "20")   ;控制快慢
  40. )
发表于 2005-4-22 17:44:00 | 显示全部楼层
你的xyp_lib.fas        原码可否共享,以便指导学习!
发表于 2005-4-23 11:19:00 | 显示全部楼层
我在CAD2005里运行了,怎么没用呢?
发表于 2005-5-24 21:26:00 | 显示全部楼层
工作都麻木了,CAD也能娱乐。
下次我也整一个。
GMT+8, 2025-5-25 10:54 , Processed in 0.180995 second(s), 24 queries , Gzip On.
