查看: 1798|回复: 4
如何实现在new AcDbDatabase里插入一个外部图块?
发表于 2004-11-19 23:17:00 | 显示全部楼层 |阅读模式
AcDbDatabase *pDb = new AcDbDatabase();
AcDbBlockTable *pBtbl;
pDb->getSymbolTable(pBtbl, AcDb::kForRead);
AcDbBlockTableRecord *pBtblRcd;
pBtbl->getAt(ACDB_MODEL_SPACE, pBtblRcd,AcDb::kForWrite);
pBtbl->close(); AcDbDatabase *pNewDb =new AcDbDatabase(Adesk::kFalse);
//acDocManager->lockDocument(acDocManager->curDocument()) ;
int es=pNewDb->readDwgFile(sFileName , _SH_DENYNO,false);
if (es!=Acad::eOk)
acutPrintf("\nThe file %s cannot be opend",sFileName);
return;
pDb->insert(AcGeMatrix3d::kIdentity, pNewDb);
pBtblRcd->close();
pDb->saveAs(DwgName);
delete pDb; 上面代码无法实现在new AcDbDatabase里插入一个外部图块,请高手指教如何实现?
发表于 2004-11-20 13:14:00 | 显示全部楼层
参考: AcDbDatabase *pNewDb =new AcDbDatabase(Adesk::kFalse);
int es=pNewDb->readDwgFile(sFileName);
if (es!=Acad::eOk)
return;
} AcDbObjectId id ;
pDb->insert (id,"myfile", pNewDb , Adesk::kFalse) ;
delete pNewDb ;
 楼主| 发表于 2004-11-21 22:45:00 | 显示全部楼层
好象不行啊? AcDbDatabase *pDb = new AcDbDatabase();
AcDb::kForWrite);
if (es!=Acad::eOk)
return;
AcDbObjectId id ;
delete pNewDb ;
pBtblRcd->close();
delete pDb;
发表于 2004-11-22 00:06:00 | 显示全部楼层
图块应理解为"对定义的引用",外部的图块必须在当前图中生成块定义后才能在当前中使用,
 楼主| 发表于 2004-11-22 21:04:00 | 显示全部楼层
没有啊,下面的代码可以将外部的DWG文件插入当前数据库: AcDbDatabase *pNewDb =new AcDbDatabase(Adesk::kFalse);
if (es!=Acad::eOk)
return;
AcDbDatabase *pDb;
pDb =acdbHostApplicationServices ()->workingDatabase () ;
return;
GMT+8, 2025-5-11 02:16 , Processed in 0.194524 second(s), 24 queries , Gzip On.
