楼主: kevinchan
如何修改成圆环(donut)-付源代码
 楼主| 发表于 2004-11-17 21:47:00 | 显示全部楼层
mccad发表于2004-11-17 21:41:00把圆直接改成圆环,是不可能的。只有通过读取圆的属性,(如圆心位置及半径),然后删除,重新按照其大小生成圆环。
针对上面的源代码,应加怎样的代码来读取和生成呢?
发表于 2004-11-17 21:49:00 | 显示全部楼层
Sub test()
On Error Resume Next
Dim ss As AcadSelectionSet
ThisDrawing.SelectionSets("Test").Delete
Set ss = ThisDrawing.SelectionSets.Add("Test")
Dim ft(0) As Integer, fd(0)
ft(0) = 0: fd(0) = "Circle"
ss.SelectOnScreen ft, fd
For Each i In ss
Cir2LW i, 1
Next i
End Sub Sub Cir2LW(ByVal oCircle, ByVal Width As Double)
Dim pnt
Dim r As Double
Dim pnts(3) As Double
Dim oLW As AcadLWPolyline
pnt = oCircle.Center
r = oCircle.radius
pnts(0) = pnt(0) - r: pnts(1) = pnt(1)
pnts(2) = pnt(0) + r: pnts(3) = pnt(1)
Set oLW = ThisDrawing.ModelSpace.AddLightWeightPolyline(pnts)
oLW.Closed = True
oLW.SetBulge 0, 1
oLW.SetBulge 1, 1
oLW.SetWidth 0, Width, Width
oLW.SetWidth 1, Width, Width
oLW.Update
oCircle.Delete
End Sub
发表于 2004-11-17 21:50:00 | 显示全部楼层
你的程序只需把Set circ = ThisDrawing.ModelSpace.AddCircle(centerpt, radius)
改成6楼所说的方法就可以了,这应该很容易完成,又何必在画完圆后再改成圆环呢?
 楼主| 发表于 2004-11-17 21:51:00 | 显示全部楼层
恩, 谢谢!!!
 楼主| 发表于 2004-11-17 21:53:00 | 显示全部楼层
我刚才试了改不成功,偶比较菜,老大可以帮我修改一下源码吗?
谢谢!
发表于 2004-11-17 22:06:00 | 显示全部楼层
加一个函数 Sub AddDonut(ByVal Center, ByVal Radius As Double, ByVal Width As Double)
pnts(0) = Center(0) - Radius: pnts(1) = Center(1)
pnts(2) = Center(0) + Radius: pnts(3) = Center(1)
oLW.Closed = True
oLW.SetBulge 0, 1
oLW.SetBulge 1, 1
oLW.Update
End Sub 把 Set circ = ThisDrawing.ModelSpace.AddCircle(centerpt, radius) 改为 AddDonut centerpt,radius, 1
 楼主| 发表于 2004-11-17 22:37:00 | 显示全部楼层
搞定,非常感谢lzh和mccad的帮忙!
GMT+8, 2025-6-13 21:47 , Processed in 0.195487 second(s), 17 queries , Gzip On.
