- 积分
- 24608
- 明经币
- 个
- 注册时间
- 2004-3-17
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - Private oSel As AcadSelectionSet
- Private TlsFt, TlsFd
- Private sName As String
- Public Sub NullFilter()
- '清空过滤器
- TlsFt = Null
- TlsFd = Null
- End Sub
- Private Function IsNull() As Boolean
- If oSel Is Nothing Then
- IsNull = True
- ElseIf oSel.Count = 0 Then
- IsNull = True
- Else
- IsNull = False
- End If
- End Function
- Public Sub Init(Optional ByVal Name As String = "TlsSel")
- '创建选择集
- On Error Resume Next
- NullFilter
- If Not oSel Is Nothing Then oSel.Delete
- sName = Name
- ThisDrawing.SelectionSets(sName).Delete
- Set oSel = ThisDrawing.SelectionSets.Add(sName)
- End Sub
- Private Sub Class_Terminate()
- '类析构时清除选择集
- End Sub
- Public Function ToArray()
- '转化选择集为对象数组输出
- Dim i
- Dim objs() As AcadEntity
- Dim nCount As Integer
- nCount = oSel.Count - 1
- ReDim objs(nCount)
- For i = 0 To nCount
- Set objs(i) = oSel(i)
- Next i
- ToArray = objs
- End Function
- Public Property Get Count() As Integer
- '获取选择集实体个数
- Count = oSel.Count
- End Property
- Public Property Get Name() As String
- '获取选择集名称
- Name = sName
- End Property
- Public Property Get Item(ByVal Index) As AcadEntity
- '获取选择集实体
- Set Item = oSel(Index)
- End Property
- Public Sub AddItems(ByVal objs)
- '向选择集加入实体
- If IsArray(objs) Then
- oSel.AddItems objs
- ElseIf IsObject(objs) Then
- Dim ents(0) As AcadEntity
- Set ents(0) = objs
- oSel.AddItems ents
- End If
- End Sub
- Public Sub RemoveItems(ByVal objs)
- '在选择集中移除实体
- oSel.RemoveItems objs
- oSel.RemoveItems ents
- End If
- End Sub
- Public Sub Clear()
- '清空选择集
- Select Case sName
- Case "PICKFIRST"
- GetPickfirstSel
- Case "CURRENT"
- GetActiveSel
- Case Else
- Init sName
- End Select
- oSel.Clear
- End Sub
- Public Sub Update()
- oSel.Update
- End Sub
- Public Function GetSel() As AcadSelectionSet
- '获取选择集
- Set GetSel = oSel
- End Function
- Public Sub GetPickfirstSel()
- '获取Pickfirst选择集
- NullFilter
- sName = "PICKFIRST"
- Set oSel = ThisDrawing.PickfirstSelectionSet
- End Sub
- Public Sub GetActiveSel()
- '获取Active选择集
- NullFilter
- sName = "CURRENT"
- Set oSel = ThisDrawing.ActiveSelectionSet
- End Sub
- Public Sub SetFilterType(ParamArray FilterType())
- '设置过滤器类型
- nCount = UBound(FilterType)
- Dim ft() As Integer
- ReDim ft(nCount)
- ft(i) = FilterType(i)
- Next i
- TlsFt = ft
- End Sub
- Public Sub SetFilterData(ParamArray FilterData())
- '设置过滤器
- nCount = UBound(FilterData)
- Dim fd()
- ReDim fd(nCount)
- fd(i) = FilterData(i)
- Next i
- TlsFd = fd
- End Sub
- Public Sub SetFilter(ParamArray Filter())
- '设置过滤器
- Dim i
- Dim n As Integer
- nCount = (UBound(Filter) + 1) / 2 - 1
- Dim ft() As Integer, fd()
- ReDim ft(nCount), fd(nCount)
- n = i * 2
- ft(i) = Filter(n)
- fd(i) = Filter(n + 1)
- Next i
- TlsFt = ft
- TlsFd = fd
- End Sub
- Public Sub AppendFilter(ParamArray Filter())
- Dim n As Integer, oCount As Integer, nCount As Integer
- oCount = UBound(TlsFt)
- n = oCount + nCount
- ReDim Preserve TlsFt(n), TlsFd(n)
- For i = 0 To nCount - 1
- n = oCount + i + 1
- TlsFt(n) = Filter(i * 2)
- TlsFd(n) = Filter(i * 2 + 1)
- Next i
- End Sub
- Public Sub SelectObjectOnScreen()
- If IsArray(TlsFt) Then
- oSel.SelectOnScreen TlsFt, TlsFd
- Else
- End If
- End Sub
- Public Sub Selectobject(ByVal Mode As AcSelect, Optional ByVal Point1, Optional ByVal Point2)
- If IsMissing(Point1) Then
- oSel.Select Mode, , , TlsFt, TlsFd
- Else
- oSel.Select Mode, Point1, Point2, TlsFt, TlsFd
- End If
- Else
- oSel.Select Mode
- Else
- End If
- End If
- End Sub
- Public Sub SelectObjectAtPoint(ByVal Point)
- oSel.SelectAtPoint Point, TlsFt, TlsFd
- Else
- End If
- End Sub
- Public Sub SelectObjectByPolygon(ByVal Mode As AcSelect, Optional ByVal Points, Optional ByVal Point2)
- oSel.SelectByPolygon Mode, Points, TlsFt, TlsFd
- Else
- End If
- End Sub
- Public Property Let Visible(ByVal Value As Boolean)
- If IsNull() Then Exit Property
- Dim i As AcadEntity
- For Each i In oSel
- i.Visible = Value
- Next i
- End Property
- Public Property Let Layer(ByVal Value As String)
- i.Layer = Value
- Next i
- End Property
- Public Property Let LineType(ByVal Value As String)
- i.LineType = Value
- Next i
- End Property
- Public Property Let Color(ByVal Value As ACAD_COLOR)
- i.Color = Value
- Next i
- End Property
- Public Sub Move(Optional ByVal Point1, Optional ByVal Point2)
- If IsNull() Then Exit Sub
- If IsMissing(Point1) Then Point1 = CreatePoint()
- If IsMissing(Point2) Then Point2 = CreatePoint()
- i.Move Point1, Point2
- Next i
- End Sub
- Public Function Copy(Optional ByVal Point1, Optional ByVal Point2)
- Dim i
- ReDim objs(Count - 1)
- For i = 0 To Count
- Set objs(i) = oSel(i).Copy
- objs(i).Move Point1, Point2
- Next i
- Copy = objs
- End Function
- Public Sub Rotate(Optional ByVal BasePoint, Optional ByVal RotationAngle As Double = 1#)
- If IsMissing(BasePoint) Then BasePoint = CreatePoint()
- i.Rotate BasePoint, RotationAngle
- Next i
- End Sub
- Public Sub Rotate3D(Optional ByVal Point1, Optional ByVal Point2, Optional ByVal RotationAngle As Double = 1#)
- i.Rotate3D Point1, Point2, RotationAngle
- Next i
- End Sub
- Public Sub ScaleAll(Optional ByVal BasePoint, Optional ByVal ScaleFactor As Double = 1)
- i.ScaleEntity BasePoint, ScaleFactor
- Next i
- End Sub
- Public Sub Mirror(Optional ByVal Point1, Optional ByVal Point2)
- i.Mirror Point1, Point2
- Next i
- End Sub
- Public Sub Mirror3D(Optional ByVal Point1, Optional ByVal Point2, Optional ByVal Point3)
- If IsMissing(Point3) Then Point3 = CreatePoint()
- i.Mirror3D Point1, Point2, Point3
- Next i
- End Sub
- Public Sub Highlight(Optional ByVal HighlightFlag As Boolean = True)
- i.Highlight HighlightFlag
- Next i
- End Sub
- Public Sub Delete()
- oSel.Erase
- End Sub
- Public Sub CopyObjects(Optional ByVal Owner, Optional ByVal IdPairs)
- If IsMissing(Owner) Then
- If IsMissing(IdPairs) Then
- ThisDrawing.CopyObjects ToArray
- Else
- ThisDrawing.CopyObjects ToArray, , IdPairs
- End If
- Else
- ThisDrawing.CopyObjects ToArray, Owner
- Else
- ThisDrawing.CopyObjects ToArray, Owner, IdPairs
- End If
- End If
- End Sub
- Public Sub GetBoundingBox(ByRef MinPoint, ByRef MaxPoint)
- Dim i
- Dim d1, d2, p1, p2
- oSel(0).GetBoundingBox d1, d2
- For i = 1 To Count - 1
- oSel(i).GetBoundingBox p1, p2
- If p1(0) < d1(0) Then d1(0) = p1(0)
- If p1(1) < d1(1) Then d1(1) = p1(1)
- If p2(0) > d2(0) Then d2(0) = p2(0)
- If p2(1) > d2(1) Then d2(1) = p2(1)
- Next i
- MinPoint = d1
- MaxPoint = d2
- End Sub
- Public Function CreatePoint(Optional ByVal X As Double = 0#, Optional ByVal Y As Double = 0#, Optional ByVal Z As Double = 0#)
- Dim pnt(2) As Double
- pnt(0) = X: pnt(1) = Y: pnt(2) = Z
- CreatePoint = pnt
- End Function
- Public Function ToBlock(Optional ByVal InsertionPoint, Optional ByVal Name As String = "*U") As String
- On Error GoTo ErrHandle
- If IsMissing(InsertionPoint) Then InsertionPoint = CreatePoint()
- If IsNull() Then Exit Function
- Dim oBlock As AcadBlock
- Set oBlock = ThisDrawing.Blocks.Add(InsertionPoint, Name)
- CopyObjects oBlock
- ToBlock = oBlock.Name
- ErrHandle:
- End Function
