查看: 1334|回复: 4
帮我看看代码,怎么不能选择?
发表于 2004-11-3 14:13:00 | 显示全部楼层 |阅读模式
On Error Resume Next
Dim sstext As AcadSelectionSet
Dim FilterType(0 To 5) As Integer
Dim FilterData(0 To 5) As Variant Set sstext = ThisDrawing.SelectionSets.Add("SSS1")
If Err Then
Err.Clear
Set sstext = ThisDrawing.SelectionSets.Item("SSS1")
End If
FilterType(0) = 0: FilterData(0) = "<or"
FilterType(1) = 0: FilterData(1) = "LINE"
FilterType(2) = 0: FilterData(2) = "Circle"
FilterType(3) = 0: FilterData(3) = ">or"
sstext.SelectOnScreen FilterType, FilterData 不能选择线了,看看什么问题?先谢了
发表于 2004-11-3 14:19:00 | 显示全部楼层
Dim FilterType(0 To 3) As Integer
Dim FilterData(0 To 3) As Variant
发表于 2004-11-3 16:27:00 | 显示全部楼层
Dim FilterType(0) As Integer
Dim FilterData(0) As Variant FilterType(0) = 0: FilterData(0) = Line,Circle"
 楼主| 发表于 2004-11-4 08:20:00 | 显示全部楼层
谢谢lzh741206斑竹
发表于 2004-11-5 17:05:00 | 显示全部楼层
为什么可以这样?不能FilterData(0 to 1)吗?
GMT+8, 2025-6-13 06:59 , Processed in 0.152861 second(s), 23 queries , Gzip On.
