查看: 1698|回复: 2
利用一个textbox增加MsFlexGrid 的编辑功能的问题
发表于 2004-11-1 14:50:00 | 显示全部楼层 |阅读模式
在vb中利用下面代码可以实现利用一个textbox增加MsFlexGrid 的编辑功能(MsFlexGrid 可以设置为处于最底层),而在vba中却不可以(由于MsFlexGrid 总是处于最顶层),为什么?怎么改? Public i As Integer
Public j As Integer
Private Sub MSFlexGrid1_Click()
TextBox1.Visible = False
End Sub Private Sub MSFlexGrid1_DblClick()
i = MSFlexGrid1.Col
j = MSFlexGrid1.Row
With MSFlexGrid1
TextBox1.Move .Left + .CellLeft, .top + .CellTop, .CellWidth, .CellHeight
TextBox1.Text = .Text
TextBox1.Visible = True
TextBox1.SetFocus
End With
End Sub Private Sub MSFlexGrid1_Scroll()
End Sub Private Sub textbox1_LostFocus() MSFlexGrid1.TextMatrix(j, i) = TextBox1.Text
End Sub Private Sub UserForm_Initialize()
MSFlexGrid1.Rows = 10
MSFlexGrid1.Cols = 2
MSFlexGrid1.FixedCols = 1
MSFlexGrid1.FixedRows = 0
MSFlexGrid1.ColWidth(0) = 1600
MSFlexGrid1.ColWidth(1) = 1500
MSFlexGrid1.Row = 0
MSFlexGrid1.Col = 0
MSFlexGrid1.Text = "a1"
MSFlexGrid1.Row = 1
MSFlexGrid1.Col = 0
MSFlexGrid1.Text = "a2"
MSFlexGrid1.Row = 2
MSFlexGrid1.Col = 0
MSFlexGrid1.Text = "a3"
MSFlexGrid1.Row = 3
MSFlexGrid1.Col = 0
MSFlexGrid1.Text = "a4" MSFlexGrid1.Row = 4
MSFlexGrid1.Col = 0
MSFlexGrid1.Text = "a5"
MSFlexGrid1.Row = 5
MSFlexGrid1.Col = 0
MSFlexGrid1.Text = "a6"
MSFlexGrid1.Row = 6
MSFlexGrid1.Col = 0
MSFlexGrid1.Text = "a7"
MSFlexGrid1.Row = 7
MSFlexGrid1.Col = 0
MSFlexGrid1.Text = "a8"
MSFlexGrid1.Row = 8
MSFlexGrid1.Col = 0
MSFlexGrid1.Text = "a9"
MSFlexGrid1.Row = 9
MSFlexGrid1.Col = 0
MSFlexGrid1.Text = "a10"
End Sub
 楼主| 发表于 2004-11-5 22:18:00 | 显示全部楼层
是不是问题太简单了,怎么没有人告诉我
发表于 2004-11-5 22:43:00 | 显示全部楼层
VBA中是不太好用,试试DB Grid吧,那个控件直接可以编辑。
GMT+8, 2025-6-13 06:45 , Processed in 0.190944 second(s), 24 queries , Gzip On.
