- 积分
- 863
- 明经币
- 个
- 注册时间
- 2004-8-13
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼主 |
发表于 2004-10-15 18:41:00
显示全部楼层
我写的代码如下:
Dim objMLine As AcadMLine, pnt ThisDrawing.Utility.GetEntity objMLine, pnt, "请选择插入点:" If Not objMLine.ObjectName = "AcDbMline" Then ThisDrawing.Utility.Prompt "请选择插入点" Exit Sub End If Dim tmpCircle As AcadCircle Set tmpCircle = ThisDrawing.ModelSpace.AddCircle(pnt, 0.5) Dim tmpPoint As Variant tmpPoint = objMLine.IntersectWith(tmpCircle, acExtendBoth) Dim pnt1(0 To 2) As Double pnt1(0) = tmpPoint(3) pnt1(1) = tmpPoint(4) pnt1(2) = tmpPoint(5) Dim pnt2(0 To 2) As Double pnt2(0) = tmpPoint(0) pnt2(1) = tmpPoint(1) pnt2(2) = tmpPoint(2)
Dim tmpLine As AcadLine Set tmpLine = ThisDrawing.ModelSpace.AddLine(pnt2, pnt1)
