查看: 1816|回复: 6
有关块属性的读取
发表于 2004-10-14 17:03:00 | 显示全部楼层 |阅读模式
再次麻烦版主了,lzh741206
知道块名:a;块属性标记:如图号的属性标记值为:th;
如何快速找到这个块,并把图号的属性标记值为th的文字内容读出来,我用vb6.0,引用object cad 2004库,请列出源代码,谢谢!
发表于 2004-10-15 00:10:00 | 显示全部楼层
依据块名作选择集; 然后用下面方法得到属性: ' Get the attributes for the block reference
Dim varAttributes As Variant
varAttributes = blockRefObj.GetAttributes
Dim strAttributes As String
Dim I As Integer
For I = LBound(varAttributes) To UBound(varAttributes)
strAttributes = strAttributes & " Tag: " & varAttributes(I).TagString & _
" Value: " & varAttributes(I).textString & " "
Next
 楼主| 发表于 2004-10-15 09:05:00 | 显示全部楼层
依据块名作选择集,怎么做,谢谢
发表于 2004-10-15 09:08:00 | 显示全部楼层
(entget(car(entsel)))
命令行键入,选择一个块看看结果
发表于 2004-10-15 09:22:00 | 显示全部楼层
作选择集: Public Sub test()
' Create the selection set
Dim ssetObj As AcadSelectionSet
Set ssetObj = ThisDrawing.SelectionSets.Add("SSET") Dim mode As Integer mode = acSelectionSetAll
' Add all the Circles to the selection set that lie within the crossing of (28,17,0) and
' (-3.3, -3.6,0) by filtering from the current drawing
Dim gpCode(0 To 1) As Integer
Dim dataValue(0 To 1) As Variant
gpCode(0) = 0
dataValue(0) = "Insert"
gpCode(1) = 2
dataValue(1) = "a" '块名
Dim groupCode As Variant, dataCode As Variant
groupCode = gpCode
dataCode = dataValue
ssetObj.Select mode, , , groupCode, dataCode MsgBox ssetObj.Count
'然后你循环ssetObj中的每个块实体...
End Sub
发表于 2004-10-15 18:15:00 | 显示全部楼层
这样吧: Sub test()
Dim blks As AcadBlocks
Dim blk As AcadBlock
Set blks = ThisDrawing.Blocks
Set blk = blks.Item("a")
Dim i As Integer
For i = 0 To blk.Count - 1
Dim obj As AcadObject
Set obj = blk.Item(i)
Dim str As String
str = obj.ObjectName
If obj.ObjectName = "AcDbAttributeDefinition" Then
Dim attrObj As AcadAttribute
Set attrObj = obj
Dim tag, prompt, value As String
tag = attrObj.TagString
prompt = attrObj.PromptString
value = attrObj.TextString
MsgBox "Tag: " & tag & vbCr & "Value: " & value & vbCr & "Value: " & value & vbCr
End If
Next
End Sub 测试dwg:
 楼主| 发表于 2004-10-18 17:38:00 | 显示全部楼层
王咣生版主:
我能看到你的dwgtext的内容,但运行程序就是看不到我的图框里的内容,百思不得其解,麻烦你看看是怎么回事,比如我想看块tbz00的drawno标记的属性文字,总为空,读drawno这个tagstring倒是可以读到。
dwg图已发到你的邮箱里了,谢谢
GMT+8, 2025-6-12 17:06 , Processed in 0.171757 second(s), 24 queries , Gzip On.
