查看: 3913|回复: 3
[LISP]直接填充自定X,Y尺寸的LSP!(画天花特方便)
发表于 2004-10-2 21:58:00 | 显示全部楼层 |阅读模式
我这有一个能修改原有HATCH文件(grid.pat),而直接填充自定X,Y尺寸(但是好象只能输入300,600,900,1200的建筑基数)的LSP,可以作为参考,加以完善命令! 希望有人能改改,使之修改HATCH的比例或间距的命令改为能单独修改HATCH的X,Y轴的比例或间距!
;[XG.LSP]BY jeep 08Jan04
;TO DRAW CEILING GRID
(defun c:xg (/ a -a b c)
(getnewline)
(setvar "cmdecho" 0)
(setq snap (getvar "osmode"))
(setq OLDERR *ERROR*
*ERROR* MYERROR
pt1 (getpoint "\nSetting up point:")
distY (getstring "\nLength of grid :")
distX (getstring "\nHeight of grid :")
pt2 (getpoint pt1 "\nAngle of grid :")
(setq angleX (angle pt1 pt2))
(setq angleY (+ angleX (/ 3.14159265358979323846264338327950288419716939937510 2)))
(setq angleX (* angleX 57.2957795130823208767981548141326))
(setq angleY (* angleY 57.2957795130823208767981548141326))
(setq Line1 (strcat (rtos angleX 2 5) ",0,0,0," distX))
(setq Line2 (strcat (rtos angleY 2 5) ",0,0,0," distY))
(setq FILENAME "GRID.PAT")
(setq OPENFILE (open FILENAME "w"))
(write-line "*GRID, XGrid" OPENFILE)
(write-line Line1 OPENFILE)
(write-line Line2 OPENFILE)
(write-line "" OPENFILE)
(close OPENFILE)
(princ "\nSelect Polyline to fill:")
(setq select (ssget))
(command "snapbase" pt1)
(command "-bhatch" "P" "GRID" "" "" "S" select "" "")
(command "snapbase" 0,0)
(setq *ERROR* OLDERR)
);END OF XG.LSP
发表于 2004-10-4 01:05:00 | 显示全部楼层
哇~~~这个程序为什么要把 pi 值用"3.14159265358979323846264338327950288419716939937510"表示???
 楼主| 发表于 2004-10-4 09:46:00 | 显示全部楼层
这是那个填充文件GRID.PAT *GRID, XGrid
90, 0,0, 0,1000
90, 100,0, 0,1000
0, 0,0, 0,450, -100,900
 楼主| 发表于 2004-11-5 11:06:00 | 显示全部楼层
版主帮忙改改!
GMT+8, 2025-5-25 10:29 , Processed in 0.143795 second(s), 23 queries , Gzip On.
