查看: 10551|回复: 26
用多边形区域选择方式构造选择集的问题
发表于 2004-9-24 16:43:00 | 显示全部楼层 |阅读模式
请教斑竹:
        构造选择集的时候,如果用CP或F构造选择集的时候,需要构造一个点链表。在知道链表的个数的前提下;可以这样做:
        pt1 pt2 pt3 分别赋值后,然后调用 pointlist=acutBulidList(RTPOINT,pt1,RTPOINT,pt2,……,0)函数构造链表
然后建立选择集 acedSSGet("CP",pointlist,NULL,NULL,ssname);
如果让用户选择的方式,构造多边形,事先不知道多少点,请问怎么建链表??
谢谢
发表于 2004-9-24 22:14:00 | 显示全部楼层
试验不成功
帮我找找原因: // ----- asdkDynRb._DYNRB command (do not rename)
static void asdkDynRb_DYNRB(void)
// Add your code for command asdkDynRb._DYNRB here
ads_point pick, lastpt;
int nRet;
ads_name ss;
struct resbuf *ptList = NULL;
struct resbuf *rbTrav ;
struct resbuf *newRb;
Adesk::Boolean keepPicking = Adesk::kTrue;
Adesk::Boolean firstPick = Adesk::kTrue; while (keepPicking)
if (firstPick)
nRet = acedGetPoint(NULL, "\nPick first point: ", pick);
firstPick = Adesk::kFalse; newRb = acutNewRb(RTPOINT);
newRb->resval.rpoint[0] = pick[0];
newRb->resval.rpoint[1] = pick[1];
newRb->resval.rpoint[2] = pick[2];
ptList = newRb;
rbTrav = newRb;
//if (newRb)
// acutRelRb(newRb);
else
acdbPointSet(pick, lastpt);
nRet = acedGetPoint(pick, "\nPick next point - [ENTER] for exit: ", pick);
acedGrDraw(lastpt, pick, 1, 0); newRb = acutNewRb(RTPOINT);
rbTrav->rbnext = newRb;
rbTrav = rbTrav->rbnext;
//if (newRb)
if (nRet != RTNORM)
keepPicking = Adesk::kFalse;
break;
} }// while
// Clear out the grdraw drawn vectors
//acedRedraw(NULL, 1); //newRb = acutNewRb(RTNONE);
////rbTrav = rbTrav->rbnext;
////rbTrav = newRb;
//rbTrav->rbnext = newRb;
rbTrav->rbnext = NULL;
//rbTrav = ptList; nRet = acedSSGet("CP", ptList, NULL, NULL, ss);
if (nRet == RTNORM)
long nEnts;
nRet = acedSSLength(ss, &nEnts);
if (nRet == RTNORM) {
CString str;
str.Format("%d", nEnts);
acedAlert(str);
for (int i = 0; i < nEnts; i++) {
ads_name eName;
acedSSName(ss, i, eName);
AcDbObjectId id;
acdbGetObjectId(id, eName);
AcDbEntity *pEnt;
acdbOpenAcDbEntity(pEnt, id, AcDb::kForRead);
pEnt->highlight();
pEnt->close();
else
acedAlert("选择失败");
发表于 2004-9-24 23:00:00 | 显示全部楼层
有没有可能是需要RT3DPOINT类型的节点呢?只是猜测,没有试哦
 楼主| 发表于 2004-9-24 23:08:00 | 显示全部楼层
版主 辛苦了。
我刚开始的做法也是像斑竹这样做的。
我再想想
发表于 2004-9-24 23:10:00 | 显示全部楼层
共同考虑吧,一定会有答案的.
For AutoCAD2005源程序,试试看:
 楼主| 发表于 2004-9-25 08:12:00 | 显示全部楼层
谢谢,
我用的是AutoCAD2000,2005加载不了,说一下思想就可以了
发表于 2004-9-25 09:05:00 | 显示全部楼层
找到上面的一段代码,加到你的程序中,找找问题所在!
发表于 2004-9-25 09:11:00 | 显示全部楼层
写一个从点数组构建缓冲区链表的程序即可。
(1)仅对数组中第一个点构建链表;
(2)将后面的点逐个添加到链表中。(如果你对数据结构比较了解,这个问题就轻而易举了。)
发表于 2004-9-25 09:43:00 | 显示全部楼层
谢谢
帮忙改一下
 楼主| 发表于 2004-9-25 09:45:00 | 显示全部楼层
王咣生 斑竹就是这个思想,但不知道为什么不行。
GMT+8, 2025-5-2 04:45 , Processed in 0.183075 second(s), 26 queries , Gzip On.
