查看: 2956|回复: 3
[推荐]ARX程序調LISP程序
发表于 2004-9-23 08:49:00 | 显示全部楼层 |阅读模式
You can directly call lisp function from ObjectARX application using
acedInvoke(...).
See example:
=========LISP code start==============
(defun myfun()
(setq myfunret 2)
; If you want to be able to invoke this function from an external ObjectARX
; application, you can use vl-acad-defun to make the function accessible.
(vl-acad-defun 'myfun)
=========LISP code end===============
=========C++ code start==============
int call_lisp_function(void)
resbuf *rb_in = acutBuildList(RTSTR,"myfun",RTNONE);
resbuf *rb_out = NULL;
int rc = acedInvoke(rb_in,&rb_out);
acutRelRb(rb_in); acutRelRb(rb_out);
acedGetSym("myfunret",&rb_out);
return (RSRSLT) ;
=========C++ code end===============
发表于 2005-2-24 20:04:00 | 显示全部楼层
发表于 2005-4-8 00:13:00 | 显示全部楼层
myfun带了参数怎么搞
(参数个数不定,或类型不定)?
发表于 2005-12-16 09:24:00 | 显示全部楼层
有没有一个完整的实例呢
GMT+8, 2025-5-8 03:18 , Processed in 0.232203 second(s), 23 queries , Gzip On.
