查看: 1967|回复: 1
[求助]請教這個程序如何讓它顯亮
发表于 2004-9-17 09:31:00 | 显示全部楼层 |阅读模式
如果使它第一个选择的目标显亮?如果我只要替换一次文字,而不是批量修改,该如何修正? ;;本程序用目标文字替换需改变的文字。可以是TEXT和属性块中的属性文字
(defun c:th1(/ a b ent ent2 elist etype oldval bltxt entdata btxt ostr pt oltxt )
(princ "\n请选择复製源文字目标:")
(setq ent (nentsel))
(if (= ent nil)(setq oldval (getstring "\n请输入文字:"))
(setq ent2 ent elist (entget (car ent)) etype (cdr (assoc 0 elist))
(setq oldval (cdr (assoc 1 elist)))
(princ "\n ")
(princ "\n复製文字内容为: ") (princ oldval)
(setq q 9)
(while q
(princ "\n ")
(setq bltxt (nentsel "\n请选择需要替换的文字目标:"))
(if (= bltxt nil)(setq q nil)
(setq entdata (entget (car bltxt)) btxt (cdr (assoc 1 entdata)) ostr btxt)
(setq elist (entget (car bltxt)))
(setq etype (cdr (assoc 0 elist)))
;;(setq oltxt (car (assoc 1 elist)))
(setq oltxt (cdr (assoc 1 elist)))
(if (= etype "ATTRIB")
(setq pt (cadr bltxt))
(command ".attedit" "" "" "" "" pt "" "V" "R" oldval "n")
(setq btxt oldval)
(entmod (subst (cons 1 btxt)(assoc 1 entdata) entdata))
(if (setq bltxt (car (reverse (cadddr bltxt)))) (entupd bltxt))
(princ "\n原文字为:")(princ oltxt)(princ ". 已被替换为: ")(princ oldval)(princ " .")
发表于 2004-9-23 16:51:00 | 显示全部楼层
亮显的方法:(redraw 实体名 3)
取消亮显:(redraw 实体名 4)
GMT+8, 2025-5-3 02:07 , Processed in 0.168008 second(s), 24 queries , Gzip On.
