查看: 1272|回复: 0
关于跟踪线x/y的比例
发表于 2004-9-7 17:41:00 | 显示全部楼层 |阅读模式
在LFX中,导入了栅格图像后,点击“line following"出现如下问题:
LFX does not work on images with different X/Y scales
点击“details“后出现”The image that you are operating on has different X and Y scales. In order for LFX to correctly follow this image, you need to use the STRETCH command to correct this.“但我用stretch一样不行,请各位帮帮忙吧,怎么解决这个x/y的比例一致?
GMT+8, 2025-5-18 00:52 , Processed in 0.174768 second(s), 24 queries , Gzip On.
