查看: 2392|回复: 4
请教int,double和CString如何相互转化?
发表于 2004-9-7 16:02:00 | 显示全部楼层 |阅读模式
请教如何把int,double 转化为CString????
发表于 2004-9-7 20:55:00 | 显示全部楼层
<BR>        // ----- AsdkintToCString._test command (do not rename)<BR>        static void AsdkintToCString_test(void)<BR>        {<BR>                // Add your code for command AsdkintToCString._test here<BR>                int                         a = 5;<BR>                double b = 1.25;<BR>                CString str;<BR>                str.Format("%d", a);<BR>                acedAlert(str);<BR>                str.Format("%.2f", b);<BR>                acedAlert(str);<BR>        }
 楼主| 发表于 2004-9-7 23:10:00 | 显示全部楼层
多谢版主!!!
发表于 2004-9-8 08:44:00 | 显示全部楼层
(1)CString转化为int
CString strCount = "2";
int n = atoi(strCount.GetBuffer(0));
strCount.ReleaseBuffer();
(2)CString转化为float
CString strCount = "2.0";
float f = atof(strCount.GetBuffer(0));
发表于 2004-9-8 22:32:00 | 显示全部楼层
发贴心情
谢谢啦
GMT+8, 2025-5-29 18:07 , Processed in 0.155704 second(s), 24 queries , Gzip On.
