查看: 2680|回复: 3
请教VBA的错误处理
发表于 2004-8-19 16:19:00 | 显示全部楼层 |阅读模式
我希望第二次使用程序时不会提示“ 所命名的选择集已经存在”, 用下列代码: On Error Resume Next
Set sset = ThisDrawing.SelectionSets.Add(62)
If Err Then
Err.Clear
sset.Delete
End If
sset.SelectOnScreen
For Each ent In sset
If ent.EntityName = "AcDbLine" Then
pstart = ent.StartPoint
pend = ent.EndPoint
End If
Next 运行时不会提示错误, 但却不让选择图元, 直接运行这段代码以后的语句。 请各位帮忙解决。 谢谢!
 楼主| 发表于 2004-8-19 21:33:00 | 显示全部楼层
我已经找到错误的地方, 以下这样就可以了:
Set sset = ThisDrawing.SelectionSets("62")
If Err Then
Err.Clear
sset.Delete
End If
Set sset = ThisDrawing.SelectionSets.Add("62")
sset.SelectOnScreen
发表于 2004-8-19 21:36:00 | 显示全部楼层
  1. On Error Resume Next
  2. ThisDrawing.SelectionSets("62").delete
  3. Set sset = ThisDrawing.SelectionSets.Add("62")
复制代码
发表于 2004-8-20 09:54:00 | 显示全部楼层
建立一个函数: Private Function CreateSSet(ByVal name As String) As AcadSelectionSet
On Error GoTo ERR_HANDLER
Dim ssetObj As AcadSelectionSet
Dim SSetColl As AcadSelectionSets
Set SSetColl = ThisDrawing.SelectionSets
Dim index As Integer
Dim found As Boolean
found = False For index = 0 To SSetColl.Count - 1
Set ssetObj = SSetColl.Item(index)
If StrComp(ssetObj.name, name, 1) = 0 Then
found = True
Exit For 'Important.
End If
Next
If Not (found) Then
Set ssetObj = SSetColl.Add(name)
Else
ssetObj.Delete '
End If
Set CreateSSet = ssetObj
Exit Function
ERR_HANDLER:
' just print the error the the debug window.
Debug.Print "Error in sub CreateSSet: " & Err.Number & " -- "; Err.Description
Resume ERR_END
ERR_END:
End Function
GMT+8, 2025-5-25 10:51 , Processed in 0.215294 second(s), 23 queries , Gzip On.
