查看: 1605|回复: 1
关于打开文件对话框
发表于 2004-8-11 15:46:00 | 显示全部楼层 |阅读模式
请问怎样实现打开文件的对话框啊?我用CFileDialog不能显示.....
发表于 2004-8-12 09:47:00 | 显示全部楼层
把你的代码贴上来看看。 另外,可以参考下面的代码(来自帮助文件中的例子): AcDbObjectId transId;
AcDbDatabase* pDb;
char *fname;
struct resbuf *rb; // Get a dwg file from the user.
rb = acutNewRb(RTSTR);
int stat = acedGetFileD("Pick a drawing", NULL, "dwg", 0, rb);
if ((stat != RTNORM) || (rb == NULL)) {
acutPrintf("\nYou must pick a drawing file.");
return;
} // Allocates a region of memory large enough to hold an object whose
// size is returned by acad_msize().
fname = (char*)acad_malloc(strlen(rb->resval.rstring) + 1);
strcpy(fname, rb->resval.rstring);
acutRelRb(rb);
// Open the dwg file.
pDb = new AcDbDatabase(Adesk::kFalse);
if (pDb->readDwgFile(fname) != Acad::eOk) {
acutPrintf("\nSorry, that draing is probably already open.");
return;
GMT+8, 2025-5-11 04:03 , Processed in 0.127133 second(s), 23 queries , Gzip On.
