查看: 2032|回复: 2
[ARX]版主、高手进来
发表于 2004-7-21 14:06:00 | 显示全部楼层 |阅读模式
关于添加扩展数据时,遇到一个大问题,运行addXData() 时打印出:ERROR: could not set Data :eRegappIdNotFound ,没能把数据添加,怎么办呢? (If any of the regappNames in xdata are not in the APPID table, then Acad::eRegappIdNotFound is returned
说明我们注册appName不成功 ?acdbRegApp(appName);可能不成功,它返回的是一个数字,-5001 ) //--------------
void addXData()
Acad::ErrorStatus es;
struct resbuf *pRb, *pTemp;
AcDbSymbolTable * appTable; char * appName="Test"; char * resString="abcdefgffff"; AcDbDatabase *pDb=acdbHostApplicationServices()->workingDatabase(); pDb->getRegAppTable(appTable,AcDb::kForWrite); pRb = appTable->xData(appName); if (pRb == NULL)
pRb = acutNewRb(AcDb::kDxfRegAppName); pTemp = pRb;
pTemp->resval.rstring = (char*) malloc(strlen(appName) + 1);
strcpy(pTemp->resval.rstring, appName);
else
for (pTemp = pRb; pTemp->rbnext != NULL;
pTemp = pTemp->rbnext)
acutPrintf("pRb != NULL\n");
pTemp->rbnext = acutNewRb(AcDb::kDxfXdAsciiString);
pTemp = pTemp->rbnext;
= (char*) malloc(strlen(resString) + 1);
strcpy(pTemp->resval.rstring, resString); appTable->upgradeOpen();
es=appTable->setXData(pRb);
acutPrintf(_T("\n ERROR: could not set Data (%s)\n"),acadErrorStatusText(es));
appTable->close();   acutRelRb(pRb);   acutPrintf("add data is ok\n");
发表于 2004-7-21 14:45:00 | 显示全部楼层
添加扩展数据要有一个目标对象,你这里没有啊给你个例子 void
addXdata()
    AcDbObject* pObj = selectObject(AcDb::kForRead);//选择一个对象,如一个圆什么的
    if (!pObj) {
        acutPrintf("Error selecting object\n");
        return;
     //让用户输入application name 和要添加到xdata中的字符串
    char appName[132], resString[200];
    appName[0] = resString[0] = '\0';
    acedGetString(NULL, "Enter application name: ",
        appName);
    acedGetString(NULL, "Enter string to be added: ",
        resString);
    pRb = pObj->xData(appName);
    if (pRb != NULL) {
        // 如果 xdata 存在,就找到扩展数据的尾部
    } else {
        // xdata 不存在,就注册 appName
        pTemp = pRb;
    // 添加用户输入的字符串到xdata.
    pObj->upgradeOpen();
    pObj->setXData(pRb);
    pObj->close();
    acutRelRb(pRb);
 楼主| 发表于 2004-7-21 15:13:00 | 显示全部楼层
谢谢warmrain!添加扩展数据要有一个目标对象,我的目标是appTable啊, appTable->xData是存在的函数啊。
GMT+8, 2025-5-11 01:25 , Processed in 0.179987 second(s), 23 queries , Gzip On.
