查看: 1389|回复: 2
[求助]版主救命啊!为什么不能这样?
发表于 2004-7-9 11:41:00 | 显示全部楼层 |阅读模式
我想把数据存到Table里,不知这样为什么不行?
struct resbuf *pRb, *pTemp;
AcDbSymbolTable * appTable;
char * appName="smartTest";
char * resString="abcdefgffff"; AcDbDatabase *pDb=acdbHostApplicationServices()->workingDatabase();
pDb->getRegAppTable(appTable,AcDb::kForWrite);
pRb = appTable->xData(appName);//(能这样吗?)
读出来是怎么样读的?我找了相关资料都没有,救救我啊,版主!!!!
dispbbs.asp?BoardID=14&ID=19010&replyID=10168&skin=1有个例子,但是它是对某一具体的对象进行操作的,而我们操作的是当前的图形。
发表于 2004-7-9 17:01:00 | 显示全部楼层
可以参考一下这个例子: void addXdata()
struct resbuf* prbX;
char appname[] = {"SPACEH"};
char windotype[] = {"Rect"};
ads_name ename;
AcDbObjectId entId;
AcDbObject* pObj; AcGePoint2d sp(getWindowStartPoint()); ads_point lwrleft;
lwrleft[X] = sp.x;
lwrleft[Y] = sp.y;
lwrleft[Z] = 0.0; acdbRegApp("SPACEH"); prbX = acutBuildList(AcDb::kDxfRegAppName, appname,
AcDb::kDxfXdAsciiString, windotype,
AcDb::kDxfXdInteger32, getWindowRows(),
AcDb::kDxfXdInteger32, getWindowCols(),
AcDb::kDxfXdReal, getWindowLength(),
AcDb::kDxfXdReal, getWindowHeight(),
AcDb::kDxfXdWorldXCoord, lwrleft,
RTNONE);
// Get the last entity
acdbEntLast(ename);
// Get the entity object ID
acdbGetObjectId(entId, ename); // Open the enity for a write operation
acdbOpenObject(pObj, entId, AcDb::kForWrite); // Add the extended entity data to the entity
pObj->setXData(prbX); pObj->close(); acutRelRb(prbX);
} void printXdata()
struct resbuf* pTemp;
ads_name ename;
AcDbObjectId entId;
AcDbObject* pObj; // Get the last entity
acdbEntLast(ename);
acdbOpenObject(pObj, entId, AcDb::kForRead); // Add the extended entity data to the entity
prbX = pObj->xData(appname); pObj->close(); // Print out the extended entity data
// Here I know the order of the extended entity data
pTemp = prbX; // Bypass the application name
pTemp = pTemp->rbnext;
acutPrintf("\nWindow Type = %s", pTemp->resval.rstring); pTemp = pTemp->rbnext;
acutPrintf("\nRows = %d", pTemp->resval.rint); pTemp = pTemp->rbnext;
acutPrintf("\nCols = %d", pTemp->resval.rint); pTemp = pTemp->rbnext;
acutPrintf("\nLength = %.2lf", pTemp->resval.rreal); pTemp = pTemp->rbnext;
acutPrintf("\nHeight = %.2lf", pTemp->resval.rreal); pTemp = pTemp->rbnext;
acutPrintf("\nStart Point = (%.2lf, %.2lf)", pTemp->resval.rpoint[X], pTemp->resval.rpoint[Y]);
acutRelRb(prbX);
 楼主| 发表于 2004-7-20 08:14:00 | 显示全部楼层
非常感谢spaceh! prbX = pObj->xData(appname);能不能换成pRb = appTable->xData(appname);能这样吗?这样又怎么办呢?
GMT+8, 2025-5-11 02:17 , Processed in 0.189628 second(s), 23 queries , Gzip On.
