查看: 2987|回复: 3
[LISP]設定及還原,u退回
发表于 2004-7-3 11:53:00 | 显示全部楼层 |阅读模式
(defun c:test() (s_acad_sysvar) ... (r_acad_sysvar) ) (defun s_acad_sysvar()
(setq acad_sysvar_list '("clayer" "osmode" "textstyle" "celtype"))
(setq old_sysvar_list (mapcar 'getvar acad_sysvar_list))
(command "undo" "be")
(defun r_acad_sysvar()
(command "undo" "e")
(mapcar 'setvar acad_sysvar_list old_sysvar_list)
(prin1)
发表于 2004-7-4 14:08:00 | 显示全部楼层
很好,不过我更喜欢局部变量,稍微改了一下,作成通用函数。
  1. (defun c:test ( / NEW_SYSVAR-VAL_LIST OLD_SYSVAR-VAL_LIST)   (setq  new_sysvar-val_list
  2.    (list '("clayer" "osmode" "CECOLOR" "textstyle" "celtype")
  3.                '("0" 32 "2" "standard" "ByLayer")
  4.    );;;;提供需设置的系统系统变量及新的参数,一一对应参数列表,注意参数类型的对应关系
  5.    )
  6.    (setq old_sysvar-val_list (set_acad_sysvar new_sysvar-val_list));获得旧的系统变量及参数列表;;;   (command "pline" "0,0" "20,20" "40,40" "")
  7. ;;;   (command "pline" "10,0" "20,0" "80,40" "");.......
  8.
  9.    (r_acad_sysvar old_sysvar-val_list);恢复系统设置)(defun set_acad_sysvar (sysvar-val_list / OLD_SYSVAR-VAL_LIST OLD_SYSVARVAL_LIST);设置新的系统参数,返回系统变量及旧的参数列表
  10.    (setq old_sysvarval_list (mapcar 'getvar (car sysvar-val_list)))
  11.    (mapcar 'setvar
  12.      (car sysvar-val_list)
  13.      (cadr sysvar-val_list)
  14.    )
  15.    (command "undo" "be")
  16.    (setq  old_sysvar-val_list
  17.    (list (car sysvar-val_list) old_sysvarval_list)
  18.    )
  19. )
  20. (defun r_acad_sysvar (old_sysvar-val_list / );恢复系统设置
  21.    (command "undo" "e")
  22.    (mapcar 'setvar
  23.      (car old_sysvar-val_list)
  24.      (cadr old_sysvar-val_list)
  25.    )
  26.    (prin1)
  27. )
发表于 2016-10-21 09:02:24 | 显示全部楼层
很好的源代码,谢谢楼主分享。
GMT+8, 2025-5-24 21:57 , Processed in 0.188922 second(s), 23 queries , Gzip On.
