楼主: 王咣生
ObjectARX工作日志
 楼主| 发表于 2004-9-3 13:19:00 | 显示全部楼层
暂无...
发表于 2004-9-6 10:36:00 | 显示全部楼层
用ARX开发程序中,要用acedCommand()函数调用AUTOCAD中的“OPEN”命令,具体应该怎么做?
acedCommand(RTSTR, "open", RTSTR, "My_Drawing",        0);
这样做却打不开是怎么回事,望版主赐教!
 楼主| 发表于 2004-9-6 19:25:00 | 显示全部楼层
Avoiding Problems with NEW and OPEN To avoid loss of synchronization between the AutoCAD and ARX communication interface, do not pass acedCommand() or acedCmd() NEW or OPEN. Instead, pass a script that executes NEW and OPEN, answers the prompts, and calls a function in the ARX application to return control to the ARX application. 考虑一下: AcApDocManager Class,或用Insert命令.
//取得ARX模块路径
TCHAR appFullPath[MAX_PATH];
int len = GetModuleFileName(_hdllInstance, appFullPath, MAX_PATH); CString strGridFullPath = appFullPath;
strGridFullPath = strGridFullPath.Left(strGridFullPath.ReverseFind('\\')) + "\\Data\\grid_500.dwg"; TCHAR fullpath[512];
if (acedFindFile(strGridFullPath, fullpath) == RTNORM) {
resbuf *rb;
if((rb = acutBuildList( RTSTR, "_insert",
RTSTR, strGridFullPath,
RTSTR, strInsPt,
RTSHORT, 1,
RTSHORT, 1,
RTSHORT, 0,
RTNONE)) != NULL)
if(acedCmd(rb) == RTNORM)
else
if(rb != NULL)
acutRelRb(rb);
else
acutPrintf("\n Could not find grid_500.dwg file!");
发表于 2004-9-15 09:48:00 | 显示全部楼层
版主真是个好人!
如果中国程序员都向你这样热心,那就好了!
何愁中国软件不能腾飞!
 楼主| 发表于 2004-9-15 22:24:00 | 显示全部楼层
呀,好高兴.共同提高吧.
发表于 2004-9-16 17:52:00 | 显示全部楼层
像起动界面这类的事情,以前从未想到过,因为都是产品一开始经理就定好的了,现在有这位好同志给了出来,才算是明白其道理,要是有一天也要做类似的事情,就不至于到处找了。真是好21世纪的雷锋!值得歌颂!
 楼主| 发表于 2004-9-22 11:51:00 | 显示全部楼层
点滴
14. 如何加载一个菜单文件? IAcadMenuGroups *mnuGrps = NULL;
mnuGrps->Load(BSTR MenuFileName, VARIANT BaseMenu, IAcadMenuGroup **pMenuGroup); // MenuFileName是自定义的菜单文件, BaseMenu是指什么呢? 方法:
CString mac = "(COMMAND \"_MENULOAD\" \"acad_map.mnu\")";
if (acDocManager->curDocument()) {
acedPostCommand( mac );
mac = "(menucmd \"P10=+ACAD_MAP.地形图缩编\")"; //如果P10不存在,则新载入的菜单加到当前菜单最后面
} 15. upgradeOpen()函数用法:
acdbGetObjectId(plineId, ename);
AcDbEntity *pEntity;
acdbOpenAcDbEntity(pEntity, plineId, AcDb::kForRead);
AcDbPolyline *pLWPline = (AcDbPolyline*)pEntity; // 现在pLWPline处于打开状态
//如果要修改pLWPline的属性,必须以写的方式打开
pLWPline->upgradeOpen();
pLWPline->setElevation(0.0);
pLWPline->close(); 注意,如果在使用upgradeOpen()之前,关闭了对象,将导致错误. 如
pEntity->close(); //或 pLWPline->close();
pLWPline->setElevation(0.0); // INTERNAL ERROR: !dbobji.cpp@6159: eNotOpenForWrite
pLWPline->close(); 16. 如果一个对象已经删除,它的ID为objId,以下代码:
acdbOpenAcDbEntity(pEntity, objId, AcDb::kForRead);
结果pEntity为NULL.
if (pEntity == NULL)
acedAlert("NULL");
if (pEntity)
acedAlert("Exist");
else
acedAlert("None Exist");
if (pEntity->isErased() == Adesk::kTrue)
// 执行将出错,其实的确也没有什么疑义,本来pEntity就不曾成功指向任何实体,当然也就没有是否被Erased的判断了;
// 是不是如果pEntity曾经指向过实体对象,该对象被删除之后,就可以用这一句来判断了呢? // 而判断该实体是否已经被删除,下面的代码可以:
If (objId.isErased() != true)
acedAlert("Exist"); 17. 如何得到一个块(AcDbBlockReference)的名字?
用参考块实体的blockTableRecord()方法返回一个该block reference引用的AcDbBlockTableRecord的object ID.
打开AcDbBlockTableRecord,用getName(const char* &pName)获得块名.
AcDbBlockReference *pBlkRef = (AcDbBlockReference*)pEnt;
AcDbObjectId pBlockTableRecordId;
pBlockTableRecordId = pBlkRef->blockTableRecord();
AcDbBlockTableRecord *pBlockTableRecord;
char* blkName;
if (Acad::eOk == acdbOpenObject(pBlockTableRecord, pBlockTableRecordId, AcDb::kForRead))
pBlockTableRecord->getName(blkName);
pBlockTableRecord->close();
} 另一麻烦的方法:
char* blkName;
ads_name ssEntName;
struct resbuf *rbSSEnt;
struct resbuf *rbTrav;
int rc;
CString strBlkName = "";
acdbGetAdsName(ssEntName, pBlkRef->objectId());
rbSSEnt = acdbEntGet(ssEntName);
rbTrav = rbSSEnt;
while (rbTrav) {
switch (rbTrav->restype)
case 2:
strBlkName = rbTrav->resval.rstring;
rbTrav = rbTrav->rbnext;
}//while
 楼主| 发表于 2004-9-24 22:42:00 | 显示全部楼层
点滴: 17. VC.NET2002下调试ARX程序方法:
(1) 编译arx程序,在需要调试的位置设置断点;
(2) 在VC.NET环境下启动(F5)程序,出现窗口
["无符号化信息 - acad.exe并不包含调试信息.(未加载任何符号.)
如果仍要调试,请单击'确定'.]
(3) 点击'确定'启动一个AutoCAD的进程,
在该进程中加载编译的arx程序,进行调试.
 楼主| 发表于 2004-10-3 00:50:00 | 显示全部楼层
组实体操作
<BR>// 选择一个组实体,获得组名,删除组<BR>static void EraseGroup(void)<BR>{<BR>        ads_name ent;<BR>        AcDbObjectId objId;<BR>        int rc;<BR>        ads_point pt;
        rc = acedEntSel("\nPlease select an Group Entity: ", ent, pt);<BR>        if (rc != RTNORM) {<BR>                return;<BR>        }<BR>        acdbGetObjectId(objId, ent);<BR>        AcDbObjectPointer&lt;AcDbEntity&gt;pEnt(objId, AcDb::kForRead);<BR>        CString sGrpName;
        AcDbVoidPtrArray        *pReactors;<BR>        void                                *pSomething;<BR>        AcDbObjectId                 persObjId;<BR>        pReactors = pEnt-&gt;reactors();
        if (pReactors != NULL)<BR>        {<BR>                for (int i = 0; i &lt; pReactors-&gt;length(); i++)<BR>                {<BR>                        pSomething = pReactors-&gt;at(i);<BR>                        // Is it a persistent reactor?<BR>                        //<BR>                        if (acdbIsPersistentReactor(pSomething)) {<BR>                                persObjId = acdbPersistentReactorObjectId( pSomething );<BR>                                acutPrintf("\n\nPersistent reactor found.");<BR>                                if(pEnt.openStatus() == Acad::eOk)<BR>                                        pEnt-&gt;close();<BR>                                AcDbObjectPointer&lt;AcDbGroup&gt;pGroup(persObjId, AcDb::kForWrite);<BR>                                sGrpName = pGroup-&gt;name();<BR>                                acedAlert(sGrpName);<BR>                                pGroup-&gt;erase();<BR>                        }<BR>                }// for<BR>        }
        return;<BR>}
// 通过组名删除组实体<BR>static void EraseGroup(const char * pGroupName)<BR>{<BR>        AcDbDictionary *pGroupDict;<BR>        AcDbObjectId pGroupId;
        acdbHostApplicationServices()-&gt;workingDatabase()-&gt;getGroupDictionary(pGroupDict, AcDb::kForWrite);
        if (pGroupDict-&gt;getAt(pGroupName,pGroupId)         == Acad::eOk)<BR>        {<BR>                AcDbObjectPointer &lt;AcDbGroup&gt; pGroup(pGroupId, AcDb::kForWrite);
                pGroup-&gt;erase();<BR>                pGroupDict-&gt;remove(pGroupId);<BR>                pGroupDict-&gt;close();<BR>                pGroup-&gt;close();<BR>        }<BR>        pGroupDict-&gt;close();
        return;<BR>}
发表于 2004-10-7 16:21:00 | 显示全部楼层
奇怪,我也用的是VC++.net 2002,但是不知为什么,就是不能调试,F5启动ACAD2004进程的时候,跳出ACAD错误的信息,怪怪的,有人遇到过这样的情况吗?我还以为是2004不能调试呢
GMT+8, 2025-12-3 12:43 , Processed in 0.191674 second(s), 18 queries , Gzip On.
