查看: 2588|回复: 3
[原创][LISP]两垂直线倒内直角
发表于 2004-6-6 09:39:00 | 显示全部楼层 |阅读模式
;两垂直线倒内直角
;2004.6.5 ljc
(defun c:dj( / l ll p1)
(setq cm(getvar "cmdecho") os(getvar "osmode"))
(setvar "cmdecho" 0)
(setq l(car (nentsel "请选择直线1")) h1(getdist "线1切割值:")
ll(car (nentsel "请选择直线2")) h2(getdist "线2切割值:") )
(setq p1 (inters (cdr (assoc 10 (entget l))) (cdr (assoc 11 (entget l)))
(cdr (assoc 10 (entget ll))) (cdr (assoc 11 (entget ll))) nil))
(command "_chamfer" "d" h1 h2) (command)
(command "_chamfer" l ll)
(setq line(entlast))
(setvar "osmode" 0)
(command "rectang" (cdr (assoc 10 (entget line)))
(cdr (assoc 11 (entget line))) )
(command "trim" line "" p1 "")
(setvar "osmode" os)
(command "erase" line "")
(command "explode" (entlast) )
(setvar "cmdecho" cm) (print)
参与人数 1金钱 +1 贡献 +5 激情 +2 收起 理由
王咣生 + 1 + 5 + 2 【好评】热情
 楼主| 发表于 2004-6-10 21:11:00 | 显示全部楼层
发表于 2004-6-24 00:54:00 | 显示全部楼层
呵呵,ljcgq 回答我的求助源码被放到这里了.还有奖励,恭喜!
发表于 2012-7-12 17:21:35 | 显示全部楼层
做記號!!晚點研究!!
GMT+8, 2025-5-25 05:52 , Processed in 0.166580 second(s), 25 queries , Gzip On.
