查看: 3050|回复: 10
CorelDRAW里面的矢量图怎么样才能导入到AUOTCAD里?
发表于 2004-6-5 13:40:00 | 显示全部楼层 |阅读模式
发表于 2004-6-5 14:29:00 | 显示全部楼层
在CorelDRAW里可以直接输出为*。dwg文件
 楼主| 发表于 2004-6-5 15:46:00 | 显示全部楼层
没有的
发表于 2004-6-5 16:01:00 | 显示全部楼层
文件——另存为
发表于 2004-6-13 22:11:00 | 显示全部楼层
CorelDRAW可以直接输出为*。dwg文件,但还要进行设置,用cad打开后无法进行拉伸,查看属性显示图形为样条曲线,请教高手该如何处理。
发表于 2004-6-13 22:18:00 | 显示全部楼层
将样条曲线转为多段线(程序)
发表于 2004-6-13 22:44:00 | 显示全部楼层
请版主具体解析一下
发表于 2004-6-14 08:50:00 | 显示全部楼层
注意:(setq  NUMPT  1000)此句可修改精度。
  1. ;from 明经通道(defun  C:wsa  (/  HOLDECHO        OS      SSS  NUMPT  N
  2.           ED  ED1      PTST    PTEND  SS2  PT1      PT2
  3.           PT3  J          ENT      NNO      SS  SSL
  4.         )
  5.     (defun  VAL1  (N  SS  INDEX)
  6.         (cdr  (assoc  N  (entget  (ssname  SS  INDEX))))
  7.     )
  8.     (defun  CH_IT  (NOS)
  9.         (if  (assoc  NOS  ED)
  10.             (progn
  11.   (if  (assoc  NOS  ENT)
  12.       (setq  ENT  (subst  (assoc  NOS  ED)  (assoc  NOS  ENT)  ENT))
  13.       (setq  ENT  (append  ENT  (list  (assoc  NOS  ED))))
  14.   )
  15.   (entmod  ENT)
  16.             )
  17.         )
  18.     )
  19.     (setq  HOLDECHO  (getvar  "cmdecho"))
  20.     (setvar  "cmdecho"  0)
  21.     (command  "_.undo"  "group")
  22.     (setq  OS  (getvar  "osmode"))
  23.     (setvar  "osmode"  0)
  24.     (prompt  "
  25. Please  pick  the  spline:  ")
  26.     (setq  SSS  (ssget  '((0  .  "spline"))))
  27.     (if  SSS
  28.         (progn
  29.             (initget  (+  1  2  4))
  30.             (setq  NUMPT  1000);;精度
  31.             (setq  N  0)
  32.             (setq  SSL  (sslength  SSS))
  33.             (repeat  SSL
  34.   (prompt  (strcat  "\r  "  (itoa  (-  SSL  N))  "  ?ン          "))
  35.   (setq  ED1  (ssname  SSS  N))
  36.   (setq  ED  (entget  ED1))
  37.   (setq  PTST    (cdr  (assoc  10  ED))
  38.               PTEND  (cdr  (assoc  10  (reverse  ED)))
  39.   )
  40.   (command  "_.divide"  ED1  (*  2  NUMPT))
  41.   (setq  SS2  (ssget  "p"))
  42.   (if  (=  (logand  (cdr  (assoc  70  ED))  1)  1)
  43.       (setq  J  1)
  44.       (setq  J  0)
  45.   )
  46.   (setq  PT3  PTST)
  47.   (setq  SS  (ssadd))
  48.   (repeat  NUMPT
  49.       (setq  PT2  (VAL1  10  SS2  J))
  50.       (if  (/=  NUMPT  (/  (+  J  2)  2))
  51.           (setq  PT1  (VAL1  10  SS2  (+  1  J)))
  52.           (setq  PT1  PTEND)
  53.       )
  54.       (command  "_.arc"  PT3  PT2  PT1)
  55.       (ssadd  (entlast)  SS)
  56.       (setq  PT3  PT1)
  57.       (setq  J  (+  2  J))
  58.   )
  59.   (command  "_.pedit"  (ssname  SS  1)  ""  "j"  SS  ""  "")
  60.   (setq  ENT  (entget  (entlast)))
  61.   (foreach  NNO  '(6  8  62  48)
  62.       (CH_IT  NNO)
  63.   )
  64.   (command  "_.erase"  SS2  ED1  "")
  65.   (setq  N  (1+  N))
  66.             )
  67.             (prompt  (strcat  "\rЧΘ??                                                              ")
  68.             )
  69.         )
  70.         (alert  "Nothing  selected!!")
  71.     )
  72.     (setvar  "osmode"  OS)
  73.     (command  "_.undo"  "end")
  74.     (setvar  "cmdecho"  HOLDECHO)
  75.     (princ)
  76. )
发表于 2004-6-17 23:09:00 | 显示全部楼层
多谢版主,我得好好学习
发表于 2005-10-9 14:56:00 | 显示全部楼层
我将一位图在coreldraw里导出为DWG格式后,打开CAD怎么出现这样的情况下?
GMT+8, 2025-5-24 02:50 , Processed in 0.177792 second(s), 31 queries , Gzip On.
