查看: 2225|回复: 6
关于cad安装问题好急呀!!!!
发表于 2004-6-3 18:50:00 | 显示全部楼层 |阅读模式
各位老大哥最近我在安装CAD时出现如下事情怎么办我安装CAD2002英语版后运行出现如下提示: FATAL ERROR unhandled Access Violation Reading 0x0000 Exception at 6d39f2h 我又安装MDT6后运行还是出现出现如下提示:
unable to tun AutoCAD.
please contact your local
reseller for assistance. 现在什么都打不开了工作也不能做了请各位楼主帮帮我好急呀!!!!小弟在这里感谢各位了。
发表于 2004-6-4 17:19:00 | 显示全部楼层
下面的话看的懂吧,不懂说一句,我翻给你,老实说,我没试过。 This problem is caused by an incompatible parallel port setting. To resolve the problem, change the CMOS settings (hardware configuration settings) for the parallel port. Use one of the following settings, which work for most systems:
  • Mode: EPP or Standard/Normal/AT
  • ECP
  • Standard
  • Bi-directional
Note that not all computers use the same terms for the parallel port settings in CMOS. If the preceding settings do not exist, or do not work, try all the settings until you find one that works. Some computers do not allow the parallel port settings to be changed in the CMOS. In this case, contact the manufacturer of the computer for either instructions for changing the parallel port settings or a CMOS update that will enable you to change the parallel port settings.
 楼主| 发表于 2004-6-6 14:32:00 | 显示全部楼层
老兄看不懂呀!!!!
发表于 2004-6-11 14:00:00 | 显示全部楼层
This problem is caused by an incompatible parallel port setting. To resolve the problem, 这个问题可能是因为电脑并口设置不兼容导致的。 为了解决这个问题,你必须改变并口在CMOS中的设置(hardware configuration settings) change the CMOS settings (hardware configuration settings) for the parallel port. Use one of the following settings, which work for most systems: 进入CMOS中, 试着改变下面的设置,大多数的系统是这样的:
  • Mode: EPP or Standard/Normal/AT (这是没法翻,自己在电脑里找吧)
  • ECP
  • Standard
  • Bi-directional
Note that not all computers use the same terms for the parallel port settings in CMOS. If the preceding settings do not exist, or do not work, try all the settings until you find one that works. Some computers do not allow the parallel port settings to be changed in the CMOS. In this case, contact the manufacturer of the computer for either instructions for changing the parallel port settings or a CMOS update that will enable you to change the parallel port settings. 注意: 所有的电脑在CMOS中使用同样的并口地址,如果这些设置不存在,或者不工作,你可以试试所有的选项直到它工作为止。有一些电脑不允许在CMOS中改变并口的设置,这样请联系你的电脑厂商,让他们给你改变它,或许你需要升级你的CMOS改变你的电脑并口地址。
发表于 2004-6-11 18:09:00 | 显示全部楼层
你英文好强
发表于 2004-6-11 18:42:00 | 显示全部楼层
是不是并口狗的问题?设为ecp
 楼主| 发表于 2004-6-11 19:13:00 | 显示全部楼层
我试了但是还是没有用不知那位大侠有没有高招呀
GMT+8, 2025-5-18 14:50 , Processed in 0.149717 second(s), 24 queries , Gzip On.
