查看: 1837|回复: 3
[ARX] 请大侠帮忙,下面的2处错误什么意思
发表于 2004-5-27 14:27:00 | 显示全部楼层 |阅读模式
// WindoInfoDlg.cpp : implementation file
#include "StdArx.h"
#include "resource.h"
#include "WindoInfoDlg.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
HTREEITEM htCur, htPrev;
// CWindoInfoDlg dialog
CWindoInfoDlg::CWindoInfoDlg(CWnd* pParent /*=NULL*/)
: CAdUiDialog(CWindoInfoDlg::IDD, pParent)
//{{AFX_DATA_INIT(CWindoInfoDlg)
// NOTE: the ClassWizard will add member initialization here
//}}AFX_DATA_INIT
void CWindoInfoDlg::DoDataExchange(CDataExchange* pDX)
CDialog::DoDataExchange(pDX);
//{{AFX_DATA_MAP(CWindoInfoDlg)
// NOTE: the ClassWizard will add DDX and DDV calls here
//}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CWindoInfoDlg, CDialog)
//{{AFX_MSG_MAP(CWindoInfoDlg)
// NOTE: the ClassWizard will add message map macros here
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CWindoInfoDlg message handlers
BOOL CWindoInfoDlg::OnInitDialog()
CDialog::OnInitDialog();
m_pTreeCtrl = (CTreeCtrl*)GetDlgItem(IDC_TREE1);
m_imgList.Create(16, 15, FALSE, 9, 3);
CBitmap* pBitmap = new CBitmap;
pBitmap->LoadBitmap(IDB_WINDOW);
m_nIdxWindow = m_imgList.Add(pBitmap, RGB(0, 0, 0));
pBitmap->LoadBitmap(IDB_RECT);
m_nIdxRect = m_imgList.Add(pBitmap, RGB(0, 0, 0));
pBitmap->LoadBitmap(IDB_ARCH);
m_nIdxArch = m_imgList.Add(pBitmap, RGB(0, 0, 0));
pBitmap->LoadBitmap(IDB_APEX);
m_nIdxApex = m_imgList.Add(pBitmap, RGB(0, 0, 0));
pBitmap->LoadBitmap(IDB_WIDTH);
m_nIdxWidth = m_imgList.Add(pBitmap, RGB(0, 0, 0));
pBitmap->LoadBitmap(IDB_HEIGHT);
m_nIdxHeight = m_imgList.Add(pBitmap, RGB(0, 0, 0));
pBitmap->LoadBitmap(IDB_ROWS);
m_nIdxRows = m_imgList.Add(pBitmap, RGB(0, 0, 0));
pBitmap->LoadBitmap(IDB_COLS);
m_nIdxCols = m_imgList.Add(pBitmap, RGB(0, 0, 0));
pBitmap->LoadBitmap(IDB_STARTPT);
m_nIdxStartPt = m_imgList.Add(pBitmap, RGB(0, 0, 0));
m_pTreeCtrl->SetImageList(&m_imgList, TVSIL_NORMAL);
delete pBitmap;
AddTreeViewItems();
HTREEITEM hRoot = m_pTreeCtrl->GetRootItem();
m_pTreeCtrl->Expand(hRoot, TVE_EXPAND);
return TRUE; // return TRUE unless you set the focus to a control
// EXCEPTION: OCX Property Pages should return FALSE
void CWindoInfoDlg::AddTreeViewItems()
CString strItem("Window");
htCur = AddOneItem((HTREEITEM)NULL, strItem, (HTREEITEM)TVI_ROOT, m_nIdxWindow, TRUE);
switch(windInfo.m_nWindType)
case 0 :
strItem = "Rect";
htPrev = AddOneItem(htCur, strItem, NULL, m_nIdxRect, FALSE);
break;
case 1 :
strItem = "Arch";
htPrev = AddOneItem(htCur, strItem, NULL, m_nIdxArch, FALSE);
break;
case 2 :
strItem = "Apex";
htPrev = AddOneItem(htCur, strItem, NULL, m_nIdxApex, FALSE);
break;
strItem.Format("W = %.2lf", windInfo.m_dWindWt);
htPrev = AddOneItem(htCur, strItem, NULL, m_nIdxWidth, FALSE);
strItem.Format("H = %.2lf", windInfo.m_dWindHt);
htPrev = AddOneItem(htCur, strItem, NULL, m_nIdxHeight, FALSE);
strItem.Format("Rows = %d", windInfo.m_nRows);
htPrev = AddOneItem(htCur, strItem, NULL, m_nIdxRows, FALSE);
strItem.Format("Cols = %d", windInfo.m_nCols);
htPrev = AddOneItem(htCur, strItem, NULL, m_nIdxCols, FALSE);
strItem.Format("SP = (%.2lf, %.2lf)", windInfo.m_startPt.x, windInfo.m_startPt.y);
htPrev = AddOneItem(htCur, strItem, NULL, m_nIdxStartPt, FALSE);
HTREEITEM CWindoInfoDlg::AddOneItem( HTREEITEM hParent,
CString szText, HTREEITEM hInsAfter, int iImage, BOOL bChildren)
HTREEITEM hItem; // return value
TV_ITEM tvI; // item structure
TV_INSERTSTRUCT tvIns; // item insert structure
if(bChildren) // *** set tvI.mask member ***
tvI.mask = TVIF_TEXT | TVIF_IMAGE | TVIF_CHILDREN | TVIF_SELECTEDIMAGE; // item has children
else // item has no children
tvI.mask = TVIF_TEXT | TVIF_IMAGE | TVIF_SELECTEDIMAGE;
tvI.pszText = szText.GetBuffer(szText.GetLength()); // set text, text lenght, image
tvI.cchTextMax = szText.GetLength();
tvI.iImage = iImage;
tvI.iSelectedImage = iImage;
tvI.cChildren = 1; // allow one more level down
// do the insert
tvIns.item = tvI;
tvIns.hInsertAfter = hInsAfter;
tvIns.hParent = hParent;
hItem = m_pTreeCtrl->InsertItem(&tvIns);
return (hItem); // return (add error trap here)
}// WindoTypeDlg.cpp : implementation file
#include "StdArx.h"
#include "WindoTypeDlg.h"
#ifdef _DEBUG
#undef THIS_FILE
#endif
extern CWindoTypeDlg *g_pWindoTypeDlg;
extern CAcToolBar *g_pAcToolBar;
extern CTBGenWnd *g_pTBGenWnd;
// CWindoTypeDlg dialog
CWindoTypeDlg::CWindoTypeDlg(CWnd* pParent /*=NULL*/)
: CAdUiDialog(CWindoTypeDlg::IDD, pParent)
//{{AFX_DATA_INIT(CWindoTypeDlg)
m_nWindType = windInfo.m_nWindType;
m_nCols = windInfo.m_nCols;
m_nRows = windInfo.m_nRows;
m_dHeight = windInfo.m_dWindHt;
m_dWidth = windInfo.m_dWindWt;
m_dXVal = windInfo.m_startPt.x;
m_dYVal = windInfo.m_startPt.y;
//}}AFX_DATA_INIT
void CWindoTypeDlg::DoDataExchange(CDataExchange* pDX)
//{{AFX_DATA_MAP(CWindoTypeDlg)
DDX_Radio(pDX, IDC_RB_TYPERECT, m_nWindType);
DDX_Text(pDX, IDC_EDIT_COLS, m_nCols);
DDV_MinMaxInt(pDX, m_nCols, 1, 10);
DDX_Text(pDX, IDC_EDIT_ROWS, m_nRows);
DDV_MinMaxInt(pDX, m_nRows, 1, 10);
DDX_Text(pDX, IDC_EDIT_HEIGHT, m_dHeight);
DDV_MinMaxDouble(pDX, m_dHeight, 20., 300.);
DDX_Text(pDX, IDC_EDIT_WIDTH, m_dWidth);
DDV_MinMaxDouble(pDX, m_dWidth, 20., 300.);
DDX_Text(pDX, IDC_EDIT_XVAL, m_dXVal);
DDX_Text(pDX, IDC_EDIT_YVAL, m_dYVal);
//}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CWindoTypeDlg, CDialog)
//{{AFX_MSG_MAP(CWindoTypeDlg)
ON_BN_CLICKED(IDC_BTN_PICKPT, OnBtnPickPt)
ON_BN_CLICKED(IDC_CHK_VISTB, OnChkViewToolBar)
ON_BN_CLICKED(IDC_BTN_HIDEDLG, OnBtnHideDlg)
ON_COMMAND(ID_MENUITEM32769, OnMenuitem_dqml)
ON_COMMAND(ID_MENUITEM32772, OnMenuitem_xmg)
ON_COMMAND(ID_MENUITEM32770, OnMenuitem_jhcz)
ON_COMMAND(ID_MENUITEM32768, OnMenuitem_dxcz)
ON_COMMAND(ID_MENUITEM32771, OnMenuitem_gy)
ON_COMMAND(ID_MENUITEM32773, OnMenuitem_xjwd)
ON_COMMAND(ID_MENUITEM32775, OnMenuitem_jx)
ON_COMMAND(ID_MENUITEM32776, OnMenuitem_yx)
ON_COMMAND(ID_MENUITEM32777, OnMenuitem_ft)
ON_COMMAND(ID_MENUITEM32778, OnMenuitem_qt)
ON_COMMAND(ID_MENUITEM32782, OnMenuitem_bhsj)
ON_COMMAND(ID_MENUITEM32780, OnMenuitem_bzst)
ON_COMMAND(ID_MENUITEM32774, OnMenuitem_gb)
ON_COMMAND(ID_MENUITEM32783, OnMenuitem_biaozhu)
ON_COMMAND(ID_MENUITEM32784, OnMenuitem_scwl)
ON_COMMAND(ID_MENUITEM32785, OnMenuitem_zhaose)
ON_COMMAND(ID_MENUITEM32786, OnMenuitem_zx)
//}}AFX_MSG_MAP
ON_MESSAGE (WM_ACAD_KEEPFOCUS, onAcadKeepFocus)
END_MESSAGE_MAP()
// CWindoTypeDlg message handlers
LONG CWindoTypeDlg::onAcadKeepFocus(UINT, LONG)
return (TRUE) ;
BOOL CWindoTypeDlg::OnInitDialog()
CSpinButtonCtrl* pSpin;
pSpin = (CSpinButtonCtrl*) GetDlgItem(IDC_SPIN_COLS);
pSpin->SetRange(1, 10);
pSpin = (CSpinButtonCtrl*) GetDlgItem(IDC_SPIN_ROWS);
void CWindoTypeDlg::PostNcDestroy()
delete this;
g_pWindoTypeDlg = NULL;
CDialog::PostNcDestroy();
void CWindoTypeDlg::OnCancel()
// Do NOT call CDialog::OnCancel();
// Remember we're modeless,
// Call DestroyWindow() instead!
DestroyWindow();
void CWindoTypeDlg::OnOK()
if (!UpdateData(TRUE))
return;
// Transfer the values in the dialog
// back to the global variables
windInfo.m_dWindHt = m_dHeight;
windInfo.m_dWindWt = m_dWidth;
windInfo.m_nCols = m_nCols;
windInfo.m_nRows = m_nRows;
windInfo.m_nWindType = m_nWindType;
windInfo.m_startPt.x = m_dXVal;
windInfo.m_startPt.y = m_dYVal;
drawWindo();
void CWindoTypeDlg::OnBtnPickPt()
// Here we hide our modal dialog
// to allow the user to pick a point
AcGePoint3d pkPt;
int retCode;
ShowWindow(SW_HIDE); // Hide our dialog
acedInitGet(NULL, NULL);
retCode = acedGetPoint(NULL, "\nPick lower left corner of window: ",
asDblArray(pkPt));
switch(retCode)
case RTCAN :
case RTNONE :
pkPt.set(0.0, 0.0, 0.0);
break;
case RTNORM :
break;
m_dXVal = pkPt.x;
m_dYVal = pkPt.y;
ShowWindow(SW_SHOW); // Display our dialog again
// Transfer the data values from the member variables
// to the dialog.
UpdateData(FALSE);
void CWindoTypeDlg::OnBtnHideDlg()
void CWindoTypeDlg::OnChkViewToolBar()
CMDIFrameWnd *pAcadFrame = acedGetAcadFrame();
if(g_pAcToolBar != NULL && g_pAcToolBar->IsWindowVisible())
((CButton*) GetDlgItem(IDC_CHK_VISTB))->SetCheck(0);
pAcadFrame->ShowControlBar(g_pAcToolBar, FALSE, FALSE);
GetDlgItem(IDC_BTN_HIDEDLG)->EnableWindow(FALSE);
else if(g_pAcToolBar != NULL)
((CButton*) GetDlgItem(IDC_CHK_VISTB))->SetCheck(1);
pAcadFrame->ShowControlBar(g_pAcToolBar, TRUE, FALSE);
GetDlgItem(IDC_BTN_HIDEDLG)->EnableWindow(TRUE);
else
pAcadFrame->EnableDocking(CBRS_ALIGN_ANY);
pAcadFrame->RecalcLayout();
CAcModuleResourceOverride resOverride;
// Does the CTBGenWnd already exist?
if(g_pTBGenWnd == NULL)
g_pTBGenWnd = new CTBGenWnd;
g_pTBGenWnd->Create (NULL,
NULL,
WS_CHILD | WS_MINIMIZE,
CRect (0,0,1,1),
pAcadFrame,
10);
g_pAcToolBar = new CAcToolBar;
g_pAcToolBar->Create(pAcadFrame, g_pTBGenWnd);
g_pAcToolBar->LoadToolBar(IDR_TB_WINDDLG);
g_pAcToolBar->EnableDocking(CBRS_ALIGN_ANY);
g_pAcToolBar->SetWindowText(_T("ARX Window")) ;
pAcadFrame->FloatControlBar(g_pAcToolBar, CPoint (100, 200), CBRS_ALIGN_TOP) ;
pAcadFrame->ShowControlBar(g_pAcToolBar, TRUE, FALSE) ;
void CWindoTypeDlg::OnMenuitem_dqml()
// TODO: Add your command handler code here
acedArxLoad ( "asdkInspector.arx");
// acedArxUnload("app");
// acedCommend("");
void CWindoTypeDlg::OnMenuitem_xmg()
AcApDocument* pcurdoc;
pcurdoc = acDocManager->curDocument();
char *cmdstr="open\n";
acDocManager->sendStringToExecute(pcurdoc,cmdstr,0);
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_jhcz()
acedArxLoad ( "zbzd.arx");
char *cmdstr="zbzd\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_dxcz()
acedArxLoad ( "trop.arx");
char *cmdstr="_windo\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_gy()
AfxMessageBox("毕业设计");
void CWindoTypeDlg::OnMenuitem_xjwd()
char *cmdstr="_new\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_jx()
char *cmdstr="_rectang\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_yx()
char *cmdstr="_circle\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_ft()
char *cmdstr="_ai_box\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_qt()
char *cmdstr="_ai_sphere\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_bhsj()
char *cmdstr="_3dorbit\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_bzst()
acedArxLoad ( "pre.arx");
char *cmdstr="_ENTDSP\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_gb()
char *cmdstr="_close\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_biaozhu()
char *cmdstr="_qdim\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_scwl()
acedArxLoad ( "post.arx");
//char *cmdstr="_FEM_POST\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_zhaose()
char *cmdstr="_shademode\n";
free(cmdstr);
void CWindoTypeDlg::OnMenuitem_zx()
char *cmdstr="_line\n";
free(cmdstr);
} 运行以上程序出现以下2个一样的错误:
f:\program files\microsoft visual studio\myprojects\bysj\windoinfodlg.cpp(150) : fatal error C1010: unexpected end of file while looking for precompiled header directive
WindoTypeDlg.cpp
f:\program files\microsoft visual studio\myprojects\bysj\windotypedlg.cpp(414) : fatal error C1010: unexpected end of file while looking for precompiled header directive。
这2处错误,是什么意思啊?有人能告诉我吗,怎么改?
发表于 2004-5-28 17:16:00 | 显示全部楼层
要么在那两个cpp文件的开头加上:#include <stdafx.h>
要么在工程设置中,把针对那两个文件的设置改为:不使用预编译
 楼主| 发表于 2004-5-28 20:00:00 | 显示全部楼层
我按照你的方法都试了,错误越来越多了啊~~
不行啊,还有别的解决办法吗?
发表于 2004-6-1 10:20:00 | 显示全部楼层
可能是在WindoInfoDlg.cpp 的某个函数的末尾多加了或是少了一个"}"
GMT+8, 2025-5-14 06:37 , Processed in 0.183657 second(s), 24 queries , Gzip On.
