查看: 1529|回复: 0
我用PDB编写的dcl对话框运行正确,怎么加载不上呢。高手帮我看看,
发表于 2004-5-25 10:55:00 | 显示全部楼层 |阅读模式
我用PDB编写的dcl对话框运行正确,怎么加载不上呢。高手帮我看看, #include <aced.h>
#include <rxregsvc.h>
#include <adscodes.h>
#include "adsdlg.h"
void initApp();
void unloadApp();
void mydcl();
void CALLB print_cb(ads_callback_packet *cpkt);
void CALLB ok_cb(ads_callback_packet *cpkt);
//.............................. 接口函数部分 ..................................
void initApp()
acedRegCmds->addCommand("mydcl_COMMANDS",
"mydcl",
"mydcl",
ACRX_CMD_TRANSPARENT ,
mydcl);
void unloadApp()
acedRegCmds->removeGroup("mydcl_COMMANDS");
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* pkt)
switch (msg)
case AcRx::kInitAppMsg:
acrxDynamicLinker->unlockApplication(pkt);
acrxRegisterAppMDIAware(pkt);
initApp();
break;
case AcRx::kUnloadAppMsg:
unloadApp();
break;
default:
break;
return AcRx::kRetOK;
} void mydcl(void)
ads_hdlg hDlg;
int dcl_id,what_next;
ads_load_dialog("mydcl.dcl", &dcl_id);
if(ads_new_dialog("mydcl",dcl_id,NULLCB,&hDlg)!=RTNORM)
acedPrompt("无法初始化对话框!\n");
acedRetVoid();
ads_action_tile(hDlg, "print", print_cb);
ads_action_tile(hDlg, "accept", ok_cb);
ads_start_dialog(hDlg, &what_next);
ads_unload_dialog(dcl_id);
acedRetVoid();
static void CALLB print_cb(ads_callback_packet *cpkt)
char tbuf[80];
ads_get_tile(cpkt->dialog, "your_name", tbuf, MAX_TILE_STR);
acutPrintf("\n 刚才输入的姓名为:%s",tbuf);
static void CALLB ok_cb(ads_callback_packet *cpkt)
ads_done_dialog(cpkt->dialog,DLGOK);
.DCL是: mydcl:dialog
label="对话框";
:edit_box
label="输入你的姓名:";
key="your_name";
:button
label="输出";
key="print";
fixed=width=true;
alignment=centered;
ok_only;
} .def文件是: DESCRIPTION
LIBRARY mydcl
EXPORTS
acrxEntryPoint PRIVATE
acrxGetApiVersion PRIVATE
GMT+8, 2025-5-14 07:18 , Processed in 0.156599 second(s), 23 queries , Gzip On.
