查看: 1387|回复: 2
求助
发表于 2004-5-19 16:32:00 | 显示全部楼层 |阅读模式
Dim plineobj As AcadLWPolyline
Dim points(0 To 3) As Double
points(0) =0+textbox1: points5(1) = 0
points(2) = 100: points5(3) = 0
Set plineobj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points) Dim pline1obj As AcadLWPolyline
Dim points1(0 To 3) As Double
points1(0) =200: points1(1) = 200
points1(2) = 500: points1(3) = 500
Set pline1obj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points1) 。。。。。。 以上程序运行时,如何在textbox1=" "时,程序跳过plineobj,继续执行下面的程序
发表于 2004-5-19 19:07:00 | 显示全部楼层
if textbox1.text<>"" then points(0) =0+textbox1: points5(1) = 0
Set plineobj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points) end if
发表于 2004-5-19 19:16:00 | 显示全部楼层
points(0) =0+textbox1: points5(1) = 0-->points(0) =iif(isnumeric),------->textbox1.text),textbox1.text,0)
GMT+8, 2025-6-14 12:25 , Processed in 0.168513 second(s), 23 queries , Gzip On.
