查看: 4011|回复: 5
快速选取一层的所有对象,进行相应的操作
发表于 2004-5-19 09:15:00 | 显示全部楼层 |阅读模式
Sub QSelLayerControl()
'程序功能:快速选取一层的所有对象,进行相应的操作
Dim i As AcadEntity
Dim ss As AcadSelectionSet
Dim ft(0) As Integer, fd(0)
Dim pLayer As String
Dim pControl As String
pLayer = ThisDrawing.Utility.GetString(0, vbCrlLf & "请输入层名:")
ft(0) = 8: fd(0) = pLayer
Set ss = ThisDrawing.ActiveSelectionSet
ss.Clear
ss.Select acSelectionSetAll, , , ft, fd
If ss.Count = 0 Then
ss.Delete
ThisDrawing.Utility.Prompt "层内没有对象或层不存在!"
Else
ThisDrawing.Utility.InitializeUserInput 1, "Move Copy Erase"
pControl = ThisDrawing.Utility.GetKeyword(vbCr & "请输入操作名[Move(移动)/Copy(复制)/Erase(删除)]:")
ThisDrawing.SendCommand "." & pControl & vbCr & "p" & vbCr & vbCr
End If
'附:将下列代码Copy到acad200?doc.lsp中,执行命令QSLC
' (defun C:QSLC()
' (setvar "cmdecho" 0)
' (command "-vbarun" "qsellayercontrol")
' (setvar "cmdecho" 1)
' (princ)
End Sub
发表于 2004-6-3 15:40:00 | 显示全部楼层
你好!
         我是一个菜鸟,我不太会用你这个程序,能否给我指点一下?谢谢了。我的E :woshiyu1217@126.com
 楼主| 发表于 2004-6-3 16:01:00 | 显示全部楼层
上面是VBA代码,你要把它Copy到VBA的代码窗口里保存,在加载应用程序的启动组把保存的dvb文件加入,再把下面的Lisp代码Copy到acad200?doc.lsp中 (defun C:QSLC()
发表于 2004-7-15 20:08:00 | 显示全部楼层
修改以下看看 Sub qselect()
Dim tsel As AcadSelectionSet
Dim entry As AcadEntity
Dim tpic As Variant
Dim layerstr As String
On Error Resume Next
Set tsel = ThisDrawing.SelectionSets("topirolss")
If Err Then
Err.Clear
Set tsel = ThisDrawing.SelectionSets.Add("topirolss")
tsel.Clear
End If
ThisDrawing.Utility.GetEntity entry, tpic, "选择实体:" If Err Then
Err.Clear
Exit Sub
End If
layerstr = entry.Layer
Dim FilterType(0) As Integer
Dim FilterData(0) As Variant
FilterType(0) = 8
FilterData(0) = layerstr
tsel.Select acSelectionSetAll, , , FilterType, FilterData
tsel.Highlight (True)
If tsel.Count = 0 Then
tsel.Delete
Else
pControl = ThisDrawing.Utility.GetKeyword(vbCr & "请输入操作名[Move(移动)/Copy(复制)/Erase(删除)]:") ThisDrawing.SendCommand "." & pc & vbCr & "p" & vbCr & vbCr
End If
End Sub
发表于 2004-7-18 20:49:00 | 显示全部楼层
我不喜欢输入层名,我一般就愿意选层实体
  1. (defun c:ssl (/ el)
  2.    (if (setq el (entsel "\n选层实体:"))
  3.          (sssetfirst (setq ss (ssget "x" (list(assoc 8 (entget (car el)))))) ss)
  4.    )
  5. )
运行后,再输入copy,mirror,align,move(当然用简写命令啦,呵呵)。。。好像几乎所以的(没有对话框的)编辑命令都支持预选
 楼主| 发表于 2004-7-18 21:02:00 | 显示全部楼层
^_^,抓VBA的痛脚,PickFrist选择集,VBA实现起来比较变 态
GMT+8, 2025-5-25 10:16 , Processed in 0.178935 second(s), 24 queries , Gzip On.
