楼主: 水镜影
用VBA编程,画一条曲线,如用三个点,怎么画?
发表于 2004-5-16 16:45:00 | 显示全部楼层
三点法(起点、第二点和终点)创建圆弧,首先计算出圆弧的圆心和半径,然后根据圆心、起点和终点,创建圆弧对象,其实现代码为:
Public Function AddArc3Pt(ByVal ptSt As Variant, ByVal ptSc As Variant, ByVal ptEn As Variant) As AcadArc
Dim objArc As AcadArc
Dim ptCen As Variant
Dim radius As Double
ptCen = GetCenOf3Pt(ptSt, ptSc, ptEn, radius)
Set objArc = AddArcCSEP(ptCen, ptSt, ptEn)
objArc.color = acGreen
objArc.Update
Set AddArc3Pt = objArc
End Function
GetCenOf3Pt是自定义的函数,能够根据三点计算出圆心和半径,其实现代码为:
Public Function GetCenOf3Pt(pt1 As Variant, pt2 As Variant, pt3 As Variant, _
ByRef radius As Double) As Variant
Dim xysm, xyse, xy As Double
Dim ptCen(2) As Double
xy = pt1(0) ^ 2 + pt1(1) ^ 2
xyse = xy - pt3(0) ^ 2 - pt3(1) ^ 2
xysm = xy - pt2(0) ^ 2 - pt2(1) ^ 2
xy = (pt1(0) - pt2(0)) * (pt1(1) - pt3(1)) - (pt1(0) - pt3(0)) * (pt1(1) - pt2(1))
'判断参数有效性
If Abs(xy) < 0.000001 Then
MsgBox "所输入的参数无法创建圆形!"
Exit Function
End If
'获得圆心和半径
ptCen(0) = (xysm * (pt1(1) - pt3(1)) - xyse * (pt1(1) - pt2(1))) / (2 * xy)
ptCen(1) = (xyse * (pt1(0) - pt2(0)) - xysm * (pt1(0) - pt3(0))) / (2 * xy)
ptCen(2) = 0
radius = Sqr((pt1(0) - ptCen(0)) * (pt1(0) - ptCen(0)) + (pt1(1) - ptCen(1)) * (pt1(1) - ptCen(1)))
If radius < 0.000001 Then
MsgBox "半径过小!"
Exit Function
End If
'函数返回圆心的位置,而半径则在参数中通过引用方式返回
GetCenOf3Pt = ptCen
End Function
需要注意的是,radius参数是按地址传递的,因此也是函数的返回值。
摘自《AutoCAD VBA精彩实例教程》第2章相关内容。
发表于 2004-5-17 09:46:00 | 显示全部楼层
GMT+8, 2025-6-15 12:15 , Processed in 0.149779 second(s), 16 queries , Gzip On.
