查看: 1661|回复: 0
[求助]
发表于 2004-4-23 11:44:00 | 显示全部楼层 |阅读模式
我有一自动制表的 lsp 程序,但用不起来,请高手帮忙,分析原因 (defun readlh( / txt len n l-lh l-n txt1 txt_1 num1 num2 num)
(setq txt (getstring)) ;读入字符
(setq txt (if txt txt "0"))
(setq len (strlen txt)
n 1
l-lh '()
l-n '()
(repeat len ;找出字符中所有","号并记录在表l-n中
(setq txt1 (substr txt n 1))
(if (= txt1 ",")
(setq l-n (cons (1- n) l-n))
) ;if end
(setq n (1+ n))
) ;repeat end
(setq l-n (cons len l-n)
l-n (reverse l-n)
l-n (cons '-1 l-n)
n (length l-n)
m 0
) ;setq end
(repeat (1- n) ;找出每个输入数值
(setq n1 (+ 2 (nth m l-n))
n2 (nth (1+ m) l-n)
n2 (- n2 n1 -1)
at (substr txt n1 n2)
m (1+ m)
) ;setq end
(setq len1 (strlen at)
num1 -1 ; "("位置
num2 -1 ; ")"位置
num 1)
(repeat len1
(Setq txt_1 (substr at num 1)
) ;setq end
(if (= txt_1 "(" ) (setq num1 num))
(if (= txt_1 ")" ) (Setq num2 num))
(setq num (1+ num))
) ;repeat end
(if (= num1 -1)
(progn ;没有找到"("号
(setq at1 (atof at)
at1 (* at1 scale)
l-lh (cons at1 l-lh)
) ;setq end
) ;progn end
(progn ;有找到"("号
(setq n_rep (atof (substr at 1 (1- num1)))
at1 (atof (substr at (1+ num1) (1- num2)))
at1 (* scale at1)
) ;setq end
(repeat (fix n_rep)
(setq l-lh (cons at1 l-lh))
) ;repeat end
) ;progn end
) ;if end
) ;repeat end
(setq l-lh (reverse l-lh))
) ;defun end
(defun C:TAB()
(inivar) ;初始化系统变量
(princ "\n表格各列之间的距离(mm,请按1:1比例输入,从左到右):" )
(setq scale (getvar "userr1"))
(setq l_x (readlh))
(princ "\n表格各行之间的距离(mm,请按1:1比例输入,从下到上):" )
(setq l_y (readlh))
(Setq len_x (length l_x)
len_y (length l_y)
lx 0
ly 0
n 0)
(repeat len_x
(setq lx (+ lx (nth n l_x))
n (1+ n)
) ;setq end
) ;repeat end
(Setq n 0)
(repeat len_y
(setq ly (+ ly (nth n l_y))
n (1+ n)
) ;setq end
) ;repeat end
(princ "\n表格插入点:")
(command "insert" "border" "x" lx "y" ly "r" 0 pause)
(setq p0 (getvar "lastpoint"))
(command "erase" "l" "" )
(setq l_x (cons '0 l_x)
l_y (cons '0 l_y)
len_x (length l_x)
len_y (length l_y)
n_x 0
n_y 0
dis 0
) ;setq end
(repeat len_x
(setq dis (+ dis (nth n_x l_x))
n_x (1+ n_x)
p1 (polar p0 0 dis)
p2 (polar p1 pi09 ly)
) ;setq end
(command "line" p1 p2 "")
) ;repeat end
(setq dis 0)
(repeat len_y
(setq dis (+ dis (nth n_y l_y))
n_y (1+ n_y)
p1 (polar p0 pi09 dis)
p2 (polar p1 0 lx)
) ;setq end
) ;repeat end
(resvar) ;还原系统变量
) ;defun end
GMT+8, 2025-5-3 01:41 , Processed in 0.170117 second(s), 23 queries , Gzip On.
