查看: 1734|回复: 1
屡战屡败,郁闷啊!!
发表于 2004-4-22 17:01:00 | 显示全部楼层 |阅读模式
最近编了几个有关CAD数据库操作的程序,结果都是出现同样的错误,提示为: E:\xgh\VC工程\OperateDb\OperateDb.cpp(209) : error C2601: 'initApp' : local function definitions are illegal
E:\xgh\VC工程\OperateDb\OperateDb.cpp(235) : error C2601: 'unloadApp' : local function definitions are illegal
E:\xgh\VC工程\OperateDb\OperateDb.cpp(241) : error C2598: linkage specification must be at global scope
E:\xgh\VC工程\OperateDb\OperateDb.cpp(242) : error C2601: 'acrxEntryPoint' : local function definitions are illegal
E:\xgh\VC工程\OperateDb\OperateDb.cpp(258) : fatal error C1004: unexpected end of file found 有关的代码是: void initApp(){
acedRegCmds->addCommand ("OPERATEDB_COMMAND",
"CREATEDB",
"CREATEDB",
ACRX_CMD_MODAL,
createDb);
void unloadApp(){
acedRegCmds->removeGroup("OPERATEDB_COMMAND");
acedRegCmds->removeGroup("LongTransaction_COMMAND");
extern"C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appid)
switch (msg)
case AcRx::kInitAppMsg:
acrxDynamicLinker->unlockApplication(appid);
acrxDynamicLinker->registerAppMDIAware(appid);
initApp();
break;
case AcRx::kUnloadAppMsg:
unloadApp();
break;
default:
break;
return AcRx::kRetOK;
} 而这些函数我都在前面声明了啊,这是怎么回事啊???? 请高手指教,谢谢!
发表于 2004-4-22 20:23:00 | 显示全部楼层
May be missing         end-symbol         '}'        , ')' or ';'         above these program codes.
GMT+8, 2025-5-11 18:26 , Processed in 0.168517 second(s), 23 queries , Gzip On.
