查看: 2437|回复: 8
快出来!!!
发表于 2004-4-20 17:53:00 | 显示全部楼层 |阅读模式
我是一个新手,刚做了一个最简单的程序,结果都没运行出来,真是郁闷啊!!在VC环境在编译出错 提示为: fatal error C1004: unexpected end of file found 这是怎么回事啊???问题出在哪了??那些库文件我都包括进去了啊,请高手指教,谢谢 我的程序:
#include<rxregsvc.h>
#include<aced.h>
#include<adslib.h>
#include "rxdlinkr.h"
void initAPP();
void unloadAPP();
void HELLOARX();
行函数,在AutoCAD中执行HELLOARX命令是被调用
void HELLOARX()
acutPrintf("hello,object2000.");
始化函数
void initAPP()
acutPrintf("\n初始化函数\n");
acedRegCmds->addCommand("HELLO_COMMANDS","HELLOARX","HELLOARX",
ACRX_CMD_MODAL,HELLOARX);
void unloadAPP()
acutPrintf("\n卸载函数\n");
acedRegCmds->removeGroup("HELLO_COMMANDS");
extern"C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appid)
switch (msg)
case AcRx::kInitAppMsg:
acrxDynamicLinker->unlockApplication(appid);
acrxDynamicLinker->registerAppMDIAware(appid);
initAPP();
break;
case AcRx::kUnloadAppMsg:
unloadAPP();
break;
return AcRx::kRetOK;
发表于 2004-4-20 20:32:00 | 显示全部楼层
该提示往往是由于括号不匹配,你这里是末尾少了括号         }
发表于 2004-4-20 20:34:00 | 显示全部楼层
switch (msg)
initAPP();
break;
unloadAPP();
break; } // Missing at here
 楼主| 发表于 2004-4-21 10:18:00 | 显示全部楼层
按照你的提示,修改后程序编译无误,可是新的问题出现了,在AUTOCAD中加载时出错,出现以下提示:
Command: _appload
acrxGetApiVersion not found in E:\xgh\VC工程\helloarx\helloarx.arx
Make sure the app links with rxapi.lib and export the symbol.AcRxDynamicLinker
failed to load 'E:\xgh\VC工程\helloarx\helloarx.arx'
E:\ACAD2000\CAD\acad.exeUnable to load helloarx.arx file.
请指教:)
发表于 2004-4-21 20:15:00 | 显示全部楼层
方法之一:
(In MSVC++ 6.0)
[Menu]                 Project -&gt; Add To Project -&gt; Files        ,                        select         Rxapi.lib
[Menu]                 File-&gt; Save Workspace
        Then,         Compile again
        OK!
发表于 2004-4-21 20:32:00 | 显示全部楼层
Have you made settings as follow? [Menu] Project->Settings... [Tab] C/C++ Category: General Preprocessor definitions: [Adding] ,ACRXAPP,RADPACK And Add lines in your Helloarx.def file: EXPORTS acrxEntryPoint _SetacrxPtp acrxGetApiVersion ================= Sorry, I have to type English words, becase it is hard to type Chinese words in my Computer.
 楼主| 发表于 2004-4-22 09:23:00 | 显示全部楼层
按照楼上两位楼主说的,我都试过了,可还是不能在CAD中载入啊,还是出现了这种错误,还有别的原因吗?请指教
发表于 2004-4-22 20:13:00 | 显示全部楼层
发贴心情
方法之一: (In MSVC++ 6.0) [Menu] Project -> Add To Project -> Files , select Rxapi.lib, Rxheap.lib, Acad.lib, Acdb15.lib, Acrx15.lib, Acutil15.lib [Menu] File-> Save Workspace Then, Compile again OK!
 楼主| 发表于 2004-4-23 09:59:00 | 显示全部楼层
问题解决拉,谢谢这位大哥
以后请多多指教
GMT+8, 2025-7-3 16:30 , Processed in 0.186337 second(s), 23 queries , Gzip On.
