查看: 336|回复: 11
[讨论] 利用dwx和archiveint.dll解压文件(找到一种解决方法)
发表于 3 天前 | 显示全部楼层 |阅读模式
;win11新版已支持解压rar,7z等格式,利用了libarchive,于是想应该有编译的dll可共利用,于是在system32里面找到了archiveint.dll,测试,是可用的
;当然,如果是win11新版可直接用http://bbs.mjtd.com/forum.php?mod=viewthread&tid=193807&extra=,不再局限于zip
;目前利用windows api设置当前目录解决解压路径问题
;函数说明及相关参考,Manpages of libarchive-dev in Debian unstable — Debian Manpageshttp://bbs.mjtd.com/forum.php?mod=viewthread&tid=177292
;均为64为系统,32位也有对应的archiveint.dll,未测试;win10 64位,win11 64位测试可行,win7测试,缺部分dll不行;只测试了.zip,.rar,.7z
;没做容错处理,cad可能会崩@yxp
  • (setq fss (getfiled "请选择压缩文件" "F:\\桌面\\" "rar;zip;7z" 0))
  • (czx:regdwx nil);注册dwx
  • (setq DWX (vlax-create-object "DynamicWrapperX"))
  • (defun DWX_reg (func args rets)
  •   (vlax-invoke DWX 'Register archdll func args rets)
  • (vlax-invoke DWX 'Register "kernel32.dll" "SetCurrentDirectoryW" "i=w" "r=l")
  • (setq path (strcat (vl-filename-directory fss) "\\cs"))
  • (vl-mkdir path)
  • (vlax-invoke DWX 'SetCurrentDirectoryW path)
  • (setq archdll (findfile "archiveint.dll"))
  • (DWX_reg "archive_read_new" "i=" "r=p") ;;; 基础句柄函数
  • (DWX_reg "archive_read_free" "i=p" "r=l");;; 基础句柄函数
  • (DWX_reg "archive_read_support_format_all" "i=p" "r=l"); ;; 格式/过滤器支持
  • (DWX_reg "archive_read_support_filter_all" "i=p" "r=l"); ;; 格式/过滤器支持
  • (DWX_reg "archive_read_open_filename" "i=psq" "r=l"); ;; 打开文件
  • (DWX_reg "archive_read_next_header" "i=pp" "r=l");;; 读取文件头
  • (DWX_reg "archive_read_extract" "i=ppl" "r=l");;解压文件
  • (DWX_reg "archive_read_close" "i=p" "r=l");;; 关闭归档
  • (setq Handle (vlax-invoke DWX 'archive_read_new))
  • (vlax-invoke DWX 'archive_read_support_format_all Handle)
  • (vlax-invoke DWX 'archive_read_support_filter_all Handle)
  • (vlax-invoke DWX 'archive_read_open_filename Handle fss 10240)
  • (setq uhead (vlax-invoke DWX 'MemAlloc 256 1))
  • (vlax-invoke DWX 'NumPut 0 uhead 0 "p")
  • (while (= 0 (vlax-invoke DWX 'archive_read_next_header Handle uhead))
  •   (setq entry (vlax-invoke DWX 'NumGet uhead 0 "p"))
  •   (vlax-invoke DWX 'archive_read_extract Handle entry 0)
  • (vlax-invoke DWX 'archive_read_close Handle) ;;rar 文件关闭
  • (vlax-invoke DWX 'archive_read_free Handle)
  • (vlax-invoke DWX 'MemFree uhead)
baitang36 + 1 很给力!
发表于 3 天前 | 显示全部楼层
sandyvs 发表于 2025-12-9 17:22
我现在纠结的是,调用解压文件的exe的话,无法判断是否解压完了,可能会导致后面的操作出错
恭喜你触发了:回调函数,回调地狱,异步,等相关编程概念.
基于你是lisp区域编程人员,本次将不会获得任何回答.
回复 支持 2 反对 0
发表于 3 天前 | 显示全部楼层
免费解压软件遍地都有,犯不上单纯为了解压还要装DWX,写这么复杂的代码
发表于 前天 00:06 | 显示全部楼层
AI写的,只支持英文
[size=11.115pt]
  • (setq fss (getfiled "请选择压缩文件" "" "rar;zip;7z" 0))
  • (setq path "C:\\temp\\")
  • (vl-mkdir path)
  • (DWX_reg "archive_entry_pathname" "i=p" "r=s")
  • (DWX_reg "archive_entry_set_pathname" "i=ps" "r=l")
  • (DWX_reg "archive_write_disk_new" "i=" "r=p")
  • (DWX_reg "archive_write_disk_set_options" "i=pl" "r=l")
  • (DWX_reg "archive_write_disk_set_standard_lookup" "i=p" "r=l")
  • (DWX_reg "archive_write_header" "i=pp" "r=l")
  • (DWX_reg "archive_write_finish_entry" "i=p" "r=l")
  • (DWX_reg "archive_write_close" "i=p" "r=l")
  • (DWX_reg "archive_write_free" "i=p" "r=l")
  • (DWX_reg "archive_read_data_block" "i=pppp" "r=l")
  • (DWX_reg "archive_write_data_block" "i=ppqq" "r=l")
  • (DWX_reg "archive_error_string" "i=p" "r=s")
  • (setq ext (vlax-invoke DWX 'archive_write_disk_new))
  • (vlax-invoke DWX 'archive_write_disk_set_options ext 3)
  • (vlax-invoke DWX 'archive_write_disk_set_standard_lookup ext)
  • (setq uhead (vlax-invoke DWX 'MemAlloc 8 1))
  • (setq pbuff (vlax-invoke DWX 'MemAlloc 8 1))
  • (setq psize (vlax-invoke DWX 'MemAlloc 8 1))
  • (setq poffset (vlax-invoke DWX 'MemAlloc 8 1))
  • (setq count 0)
  • (setq success 0)
  • (princ (strcat "\n开始解压到: " path "\n"))
  •   (setq fname (vlax-invoke DWX 'archive_entry_pathname entry))
  •   (setq targetpath (strcat path fname))
  •   (setq targetpath (vl-string-translate "/" "\\" targetpath))
  •   (setq targetdir (vl-filename-directory targetpath))
  •   (if targetdir
  •     (if (not (vl-file-directory-p targetdir))
  •       (vl-mkdir targetdir)
  •   (vlax-invoke DWX 'archive_entry_set_pathname entry targetpath)
  •   (setq r (vlax-invoke DWX 'archive_write_header ext entry))
  •   (princ (strcat "\n  写入头: " (itoa r) " - " targetpath))
  •   (if (< r 0)
  •     (princ (strcat "\n  错误: " (vlax-invoke DWX 'archive_error_string ext)))
  •   (if (>= r 0)
  •     (progn
  •       (while (= 0 (setq r (vlax-invoke DWX 'archive_read_data_block Handle pbuff psize poffset)))
  •         (setq buff (vlax-invoke DWX 'NumGet pbuff 0 "p"))
  •         (setq size (vlax-invoke DWX 'NumGet psize 0 "q"))
  •         (setq offset (vlax-invoke DWX 'NumGet poffset 0 "q"))
  •         (setq wr (vlax-invoke DWX 'archive_write_data_block ext buff size offset))
  •         (if (< wr 0)
  •           (setq r -1)
  •       (if (= r 1)
  •         (progn
  •           (vlax-invoke DWX 'archive_write_finish_entry ext)
  •           (setq success (1+ success))
  •           (princ (strcat "\n&#10003; " fname))
  •         (princ (strcat "\n&#10007; " fname " (数据错误)"))
  •   (setq count (1+ count))
  • (vlax-invoke DWX 'archive_write_close ext)
  • (vlax-invoke DWX 'archive_write_free ext)
  • (vlax-invoke DWX 'MemFree pbuff)
  • (vlax-invoke DWX 'MemFree psize)
  • (vlax-invoke DWX 'MemFree poffset)
  • (princ (strcat "\n\n完成!成功: " (itoa success) "/" (itoa count)))
  • (princ (strcat "\n位置: " path))
  • (princ)
 楼主| 发表于 3 天前 | 显示全部楼层
你有种再说一遍 发表于 2025-12-9 17:31
恭喜你触发了:回调函数,回调地域,异步,等相关编程概念.
基于你是lisp区域编程人员,本次将不会获得任何回 ...
好好,有时间学C#
发表于 3 天前 | 显示全部楼层
如果知道被压缩的文件个数,可以用while核查解压目标文件夹是否文件数目已经达到设定值。
另外的方式是用WSH实现EXEWAIT。
另外的方式是 ...
也不好弄,可能过段时间会更新压缩包,不能没更新一次再改次个数吧。。
用WSH实现EXEWAIT 还没研究过
发表于 3 天前 | 显示全部楼层
那就while时候去catch vl-file-delete zip文件,解压完成了,压缩文件就可以被正常删除了
如果不希望删除压缩文件,那就先复制一个副本到临时目录,再从副本解压并删除副本
 楼主| 发表于 前天 09:55 | 显示全部楼层
如果不希望删除 ...
这也是个办法
GMT+8, 2025-12-12 06:23 , Processed in 0.202376 second(s), 29 queries , Gzip On.
