查看: 778|回复: 8
下午还能用晚上用不了 了
发表于 2025-5-13 23:06:05 | 显示全部楼层 |阅读模式
(defun c:TOOLS (/ *error* dcl_id dcl_file dcl_content result)
  ;; 错误处理函数
  (defun *error* (msg)
    (if dcl_id (unload_dialog dcl_id))
    (if dcl_file (vl-file-delete dcl_file))
    (princ "\n* 工具箱已清理 *")
  ;; 对话框定义
  (setq dcl_content
"tools : dialog {
  label = \"智能绘图工具集 V2.1\";
  spacer;
  : boxed_column {
    label = \"核心工具\";
    : row {
      : button { key = \"ac\";   label = \"智能绘弧\";   width = 15; fixed_width = true; }
      : button { key = \"JX\";  label = \"快速矩形\";  width = 15; fixed_width = true; }
    : row {
      : button { key = \"zd\";  label = \"展点标注\";   width = 15; fixed_width = true; }
      : button { key = \"zb\";  label = \"坐标汇总\";   width = 15; fixed_width = true; }
  : boxed_column {
    label = \"专业工具\";
    : row {
      : button { key = \"hzq\"; label = \"挡土墙设计\"; width = 15; fixed_width = true; }
      : button { key = \"dmt\"; label = \"断面绘制\";   width = 15; fixed_width = true; }
    : row {
      : button { key = \"dmj\"; label = \"土方计算\";   width = 15; fixed_width = true; }
      : button { key = \"mjb\"; label = \"面积统计\";   width = 15; fixed_width = true; }
  : boxed_column {
    label = \"实用工具\";
    : row {
      : button { key = \"hb\";  label = \"填充处理\";   width = 15; fixed_width = true; }
      : button { key = \"MPE\"; label = \"多段线合并\"; width = 15; fixed_width = true; }
    : row {
      : button { key = \"ft\";  label = \"图纸分割\";   width = 15; fixed_width = true; }
      : button { key = \"gp\";  label = \"数据导出\";   width = 15; fixed_width = true; }
  ok_cancel;
  ;; 创建临时DCL文件
  (setq dcl_file (vl-filename-mktemp "TOOLS.dcl"))
  (if (not (setq f (open dcl_file "w")))
      (alert "无法创建临时文件!\n请检查临时目录权限")
      (exit)
  (write-line dcl_content f)
  (close f)
  ;; 加载对话框
  (if (<= (setq dcl_id (load_dialog dcl_file)) 0)
      (alert "对话框加载失败!\n可能原因:\n1. DCL语法错误\n2. 文件权限问题")
      (exit)
  ;; 初始化对话框
  (if (not (new_dialog "tools" dcl_id))
      (alert "对话框初始化失败!")
      (exit)
  ;; 定义按钮动作
  (action_tile "ac"   "(done_dialog 1)")
  (action_tile "JX"  "(done_dialog 2)")
  (action_tile "zd"  "(done_dialog 3)")
  (action_tile "zb"  "(done_dialog 4)")
  (action_tile "hzq" "(done_dialog 5)")
  (action_tile "dmt" "(done_dialog 6)")
  (action_tile "dmj" "(done_dialog 7)")
  (action_tile "mjb" "(done_dialog 8)")
  (action_tile "hb"  "(done_dialog 9)")
  (action_tile "MPE" "(done_dialog 10)")
  (action_tile "ft"  "(done_dialog 11)")
  (action_tile "gp"  "(done_dialog 12)")
  ;; 显示对话框
  (setq result (start_dialog))
  ;; 执行命令
  (cond
    ((= result 1)  (c:AC))
    ((= result 2)  (c:JX))
    ((= result 3)  (c:ZD))
    ((= result 4)  (c:ZB))
    ((= result 5)  (c:HZQ))
    ((= result 6)  (c:DMT))
    ((= result 7)  (c:DMJ))
    ((= result 8)  (c:MJB))
    ((= result 9)  (c:HB))
    ((= result 10) (c:MPE))
    ((= result 11) (c:FT))
    ((= result 12) (c:GP))
;; 初始化提示
(princ "\n★ 智能工具箱已加载,输入命令 TOOLS 启动 ★")
发表于 5 天前 | 显示全部楼层
你只加载了界面,没有加载内容,就好比你去朋友家看到他电脑上的游戏挺好玩,想要拷贝回家,然后你就把桌面的快捷方式拷贝回去了,然后就一直问为什么打不开
发表于 2025-5-13 23:22:11 | 显示全部楼层
CAD2024 窗口正常弹出~还是小白,学习中。
是不是运行环境的问题?
什么都没有动,运行正常~
 楼主| 发表于 7 天前 | 显示全部楼层
对话界面有,命令无法运行
这个对话框只是快捷方式,小程序也要带上才能用  发表于 5 天前
发表于 7 天前 | 显示全部楼层
cjf160204 发表于 2025-5-14 08:46
对话界面有,命令无法运行
没有程序辅助函数运行什么?你那个调用函数有了,调用什么呢?
tryhi + 1
发表于 7 天前 | 显示全部楼层
学习了!
是的~还要调用工具,工具的代码没有~
运行窗口前,相关工具要已加载~
发表于 6 天前 | 显示全部楼层
就是说,这个只是个面板,没有脚本内容。但是你可以自己改写,就是能得到自己的工具箱
发表于 6 天前 | 显示全部楼层
没毛病啊,可以使用
GMT+8, 2025-5-21 11:47 , Processed in 0.282085 second(s), 25 queries , Gzip On.
