查看: 463|回复: 4
[提问] 麻烦大师帮我改下如下反应器,使copy后新圆依然带反应器,谢谢!
发表于 2025-4-28 10:03:36 | 显示全部楼层 |阅读模式
CAD2016 中实现一个反应器,当绘制圆后,编辑圆时显示半径,希望使用 CAD 自带的 COPY 命令复制圆后,新圆也能触发同样的反应器。麻烦大师帮忙修改下,不胜感激!
(defun c:aa (/ cp r vla vlaLst)
  (vl-load-com)
  (setq cp (getpoint "\n指定圆心点:"))
  (setq r (getdist cp "\n输入园半径:"))
  (command "circle" cp r)
  (setq vla (vlax-ename->vla-object (entlast)))
  (setq vlaLst (list vla))
  (vlr-pers (vlr-object-reactor vlaLst nil '((:vlr-modified . show))))
(defun show (notifier-object reactor-object parameter-list / r)
  (vl-load-com)
  (setq r (vla-get-diameter notifier-object));获取直径(vla-get-diameter获取圆的直径)
  (setq r (rtos r 2 4));转换为字符串
  (alert (strcat "圆的内径是:" r))
 楼主| 发表于 2025-4-28 10:50:41 | 显示全部楼层
各位大师,麻烦帮忙啊,在此谢过了!
发表于 2025-4-28 20:05:01 | 显示全部楼层
单纯支持,给高手修改吧
发表于 2025-4-28 20:39:41 | 显示全部楼层
需要追加一个copied反应器
  1. (defun c:aa (/ cp r vla vlaLst)
  2.   (vl-load-com)
  3.   (setq cp (getpoint "\n指定圆心点:"))
  4.   (setq r (getdist cp "\n输入园半径:"))
  5.   (command "circle" cp r)
  6.   (setq vla (vlax-ename->vla-object (entlast)))
  7.   (setq vlaLst (list vla))
  8.   (vlr-pers (vlr-object-reactor vlaLst nil '((:vlr-modified . show)
  9.                                              (:VLR-COPIED . copy))))
  10.   (princ)
  11. )
  12. (defun copy (notifier-object reactor-object parameter-list / r)
  13.   (vlr-pers (vlr-object-reactor (list (vlax-ename->vla-object (entlast)))
  14.               nil '((:vlr-modified . show)
  15.                                              (:VLR-COPIED . copy))))
  16.   )
  17. (defun show (notifier-object reactor-object parameter-list / r)
  18.   (vl-load-com)
  19.   (setq r (vla-get-diameter notifier-object));获取直径(vla-get-diameter获取圆的直径)
  20.   (setq r (rtos r 2 4));转换为字符串
  21.   (alert (strcat "圆的内径是:" r))
  22. )
tender138 + 1
 楼主| 发表于 2025-4-29 08:55:59 | 显示全部楼层
kozmosovia 发表于 2025-4-28 20:39
需要追加一个copied反应器
非常感谢大师一再帮忙!!!
GMT+8, 2025-5-23 08:01 , Processed in 0.164607 second(s), 29 queries , Gzip On.
