楼主: qq1254582201
【转载】CAD多重引线相关内容转载合集
 楼主| 发表于 2025-4-16 17:08:08 | 显示全部楼层
AutoCAD .NET: MultiLeader (MLeader) Jig 4 – Jigging Block with Attribute
We provided various jig implementations before, either using EntityJig or DrawJig, either from scratch or with the assistance of the Entity Jigger or Draw Jigger of AcadNetAddinWizard(Pro).
We demonstrated how to jig a MultiLeader programmatically through an arrow location and a single landing location using AutoCAD .NET and C#. We also showed how to jig multiple landing locations. We presented last time how to jig block content instead of the default MText content. In this post, we are going to extend the jig to support any blocks having attributes defined. This will make the MLeaderJigger more flexible and useful since the block content will likely change from one case to another in the real design world.
Here we go.
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Diagnostics;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.Drawing;
using System.IO;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Windows;
using MgdAcApplication = Autodesk.AutoCAD.ApplicationServices.Application;
using MgdAcDocument = Autodesk.AutoCAD.ApplicationServices.Document;
using AcWindowsNS = Autodesk.AutoCAD.Windows;
#endregion
namespace AcadNetCSharp
    public class MLeaderJigger4 : EntityJig
        #region Fields
        private const string BlockName = "tagAtt";
        public static string TagContent = "";
        public int mCurJigFactorIndex = 1;  // Jig Factor Index
        public Autodesk.AutoCAD.Geometry.Point3d mArrowLocation; // Jig Factor #1
        public Autodesk.AutoCAD.Geometry.Point3d mLandingLocation; // Jig Factor #2
        #endregion
        #region Constructors
        public MLeaderJigger4(MLeader ent)
            : base(ent)
            Entity.SetDatabaseDefaults();
            Entity.ContentType = ContentType.BlockContent;
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                Entity.BlockContentId = bt[BlockName];
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(Entity.BlockContentId, OpenMode.ForWrite);
                if (btr.HasAttributeDefinitions)
                    foreach (ObjectId id in btr)
                        DBObject obj = tr.GetObject(id, OpenMode.ForRead);
                        if (obj is AttributeDefinition)
                            AttributeDefinition ad = obj as AttributeDefinition;
                            AttributeReference ar = new AttributeReference();
                            ar.SetAttributeFromBlock(ad, Matrix3d.Displacement(Entity.BlockPosition - Point3d.Origin));
                            ar.TextString = TagContent;
                            Entity.SetBlockAttribute(id, ar);
                tr.Commit();
            Entity.EnableDogleg = true;
            Entity.EnableLanding = true;
            Entity.EnableFrameText = false;
            Entity.AddLeaderLine(mLandingLocation);
            Entity.SetFirstVertex(0, mArrowLocation);
            Entity.TransformBy(UCS);
        #endregion
        #region Properties
        private Editor Editor
            get
                return MgdAcApplication.DocumentManager.MdiActiveDocument.Editor;
        private Matrix3d UCS
            get
                return MgdAcApplication.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem;
        #endregion
        #region Overrides
        public new MLeader Entity  // Overload the Entity property for convenience.
            get
                return base.Entity as MLeader;
        protected override bool Update()
            switch (mCurJigFactorIndex)
                case 1:
                    Entity.SetLastVertex(0, mArrowLocation);
                    break;
                case 2:
                    Entity.SetLastVertex(0, mLandingLocation);
                    break;
                default:
                    return false;
            return true;
        protected override SamplerStatus Sampler(JigPrompts prompts)
                case 1:
                    JigPromptPointOptions prOptions1 = new JigPromptPointOptions("\nArrow Location:");
                    // Set properties such as UseBasePoint and BasePoint of the prompt options object if necessary here.
                    prOptions1.UserInputControls = UserInputControls.Accept3dCoordinates | UserInputControls.GovernedByOrthoMode | UserInputControls.GovernedByUCSDetect | UserInputControls.UseBasePointElevation;
                    PromptPointResult prResult1 = prompts.AcquirePoint(prOptions1);
                    if (prResult1.Status == PromptStatus.Cancel && prResult1.Status == PromptStatus.Error)
                        return SamplerStatus.Cancel;
                    if (prResult1.Value.Equals(mArrowLocation))  //Use better comparison method if necessary.
                        return SamplerStatus.NoChange;
                    else
                        mArrowLocation = prResult1.Value;
                        return SamplerStatus.OK;
                case 2:
                    JigPromptPointOptions prOptions2 = new JigPromptPointOptions("\nLanding Location:");
                    prOptions2.UseBasePoint = true;
                    prOptions2.BasePoint = mArrowLocation;
                    prOptions2.UserInputControls = UserInputControls.Accept3dCoordinates | UserInputControls.GovernedByOrthoMode | UserInputControls.GovernedByUCSDetect | UserInputControls.UseBasePointElevation;
                    PromptPointResult prResult2 = prompts.AcquirePoint(prOptions2);
                    if (prResult2.Status == PromptStatus.Cancel && prResult2.Status == PromptStatus.Error)
                    if (prResult2.Value.Equals(mLandingLocation))  //Use better comparison method if necessary.
                    else
                        mLandingLocation = prResult2.Value;
                default:
                    break;
        #endregion
        #region Methods to Call
        public static MLeader Jig()
            MLeaderJigger4 jigger = null;
            try
                jigger = new MLeaderJigger4(new MLeader());
                PromptResult pr;
                do
                    pr = MgdAcApplication.DocumentManager.MdiActiveDocument.Editor.Drag(jigger);
                    if (pr.Status == PromptStatus.Keyword)
                        // Keyword handling code
                    else
                        jigger.mCurJigFactorIndex++;
                } while (pr.Status != PromptStatus.Cancel && pr.Status != PromptStatus.Error && jigger.mCurJigFactorIndex <= 2);
                if (pr.Status == PromptStatus.Cancel || pr.Status == PromptStatus.Error)
                    if (jigger != null && jigger.Entity != null)
                        jigger.Entity.Dispose();
                    return null;
                return jigger.Entity;
            catch(System.Exception ex)
                MgdAcApplication.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString());
                return null;
        #endregion
        #region Test Commands
        [CommandMethod("TestMLeaderJigger4")]
        public static void TestMLeaderJigger4_Method()
            try
                TagContent = MgdAcApplication.DocumentManager.MdiActiveDocument.Editor.GetString("\nTag: ").StringResult;
                Entity jigEnt = MLeaderJigger4.Jig();
                if (jigEnt != null)
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                        btr.AppendEntity(jigEnt);
                        tr.AddNewlyCreatedDBObject(jigEnt, true);
                        tr.Commit();
            catch (System.Exception ex)
        #endregion
The workflow and output may look like the following:
As can be seen, the block attribute value (tag) is collected first so that the tag with the exact string value can be jigged nicely along with the arrow, leader line, and standing line. The UCS is still perfectly honored. Before running the jig test code, please make sure a block named “tagAtt” exists and it has at least a block attribute defined. The block attribute can have any tag name. If multiple block attributes defined, all of them will have the value as input at the beginning of the jigging.
发表于 2025-4-17 08:59:39 | 显示全部楼层
用vlisp可以轻松定义和修改mleader的文字内容。
个人好奇的是:vb.net开发插件,可以实现非模态窗口,和动态显示编辑里的功能(如移动旋转吗)
vb net的学习容易吗?
发表于 2025-4-17 11:10:46 | 显示全部楼层
qq1254582201 发表于 2025-4-16 17:08
AutoCAD .NET: MultiLeader (MLeader) Jig 4 – Jigging Block with AttributeWe provided various jig imp ...
这篇有很多误导人的错误代码
发表于 2025-4-17 17:10:29 | 显示全部楼层
个人好奇的是:vb.net开发插件,可以实现非模态窗口,和动 ...
学C#吧,不然你享受不到IFox和我的博客,
.NET肯定都可以实现非模态窗口,你的问题都不是什么难题
GMT+8, 2025-5-1 06:06 , Processed in 0.132732 second(s), 17 queries , Gzip On.
