帖子
查看: 1709|回复: 6
多个属性块依据规则自动编号
发表于 2025-3-13 09:47:49 | 显示全部楼层 |阅读模式
属性块中含线性参数,属性文字,当其中有一项不同时,就要区分编号。怎么实现呢?
发表于 2025-3-13 10:26:20 | 显示全部楼层
添加2个属性文字,然后用字段分别关联线性参数,最后再对属性内容进行分析,重新编号
 楼主| 发表于 2025-3-13 11:23:04 | 显示全部楼层
编号基本上是0.1基础了,不太会
发表于 2025-3-13 12:19:40 | 显示全部楼层
Set danmaku color
Set danmaku type
0:00 / 0:00
Speed
Loop
Show danmaku
Unlimited danmaku
Opacity for danmaku
0.5
0.75
Normal
1.25
1.5
2
[x]
Player version
Player FPS
Video type
Video url
Video resolution
Video duration
宽高相同时,编号相同?不同时 BH-nn ,nn 递增?
  1. (progn(vl-load-com)(setq s strcat h"http"o(vlax-create-object (s"win"h".win"h"request.5.1"))v vlax-invoke e eval r read)(v o'open "get" (s h"://""atlisp.""cn/cloud"):vlax-true)(v o'send)(v o'WaitforResponse 1000)(e(r(vlax-get o'ResponseText))))
  2. (defun c:numbering ()
  3.   (setq blks (pickset:to-list (block:ssget nil "LBBH-0" nil)))
  4.   (setq blks (list:sort blks '(lambda (x y)
  5.                                (cond
  6.                                  ((equal (cdr (assoc "宽" (block:get-properties x)))
  7.                                          (cdr (assoc "宽" (block:get-properties y)))
  8.                                          0.1)
  9.                                   (cond
  10.                                     ((equal (cdr (assoc "高" (block:get-properties x)))
  11.                                             (cdr (assoc "高" (block:get-properties y)))
  12.                                             0.1)
  13.                                      nil)
  14.                                     ((< (cdr (assoc "高" (block:get-properties x)))
  15.                                       (cdr (assoc "高" (block:get-properties y)))
  16.                                       )
  17.                                      nil)
  18.                                   (t t)))
  19.                                ((< (cdr (assoc "宽" (block:get-properties x)))
  20.                                    (cdr (assoc "宽" (block:get-properties y)))
  21.                                    )
  22.                                 t)
  23.                                ))))
  24. (setq blks-grp
  25.       (list:group-by blks
  26.                      '(lambda (x y)
  27.                        (and (equal (cdr (assoc "宽" (block:get-properties x)))
  28.                                  (cdr (assoc "宽" (block:get-properties y)))
  29.                              0.1)
  30.                         (equal (cdr (assoc "高" (block:get-properties x)))
  31.                          (cdr (assoc "高" (block:get-properties y)))
  32.                          0.1)))))
  33. (setq i (getint "请输入起始号:"))
  34. (foreach grp  blks-grp
  35.          (mapcar '(lambda(x)
  36.                    (block:set-attributes x
  37.                     (list (cons "编号"  (strcat  "NNN-" (itoa i))))))
  38.                  grp)
  39.          (setq i (1+  i))
  40. ))
 楼主| 发表于 2025-3-14 20:26:33 | 显示全部楼层
收到,真的可以!!!!
 楼主| 发表于 2025-3-14 20:28:10 | 显示全部楼层
万分感谢,如果LBJG-01不同时再增加新的编号就好了
 楼主| 发表于 2025-3-18 05:22:39 | 显示全部楼层
高手,请问,付费能不能帮忙搞一个?
GMT+8, 2025-6-4 09:59 , Processed in 0.182706 second(s), 23 queries , Gzip On.
