查看: 1551|回复: 12
[源码] 绘制五彩雪花,新手之作
发表于 2025-2-20 10:27:26 | 显示全部楼层 |阅读模式
;以指定点为中心随机绘制六种雪花中的一种,大小在0.6~1.0倍间随机,颜色在七种中随机
;新手之作,请勿见笑!
  1. (defun c:yt_snow(/  v1 v2 v3)
  2.   (setq v1(getvar "osmode"))
  3.   (setq v2(getvar "cmdecho"))
  4.   (setq v3(getvar "blipmode"))
  5.   (setq p1 (getpoint "\n指定雪花中心:"));注意雪花应保持一定距离,否则会造成干扰
  6.
  7.   (setvar "osmode" 0)
  8.   (setvar "cmdecho" 0)
  9.   (setvar "blipmode" 0)
  10.   (setq n (rem (fix (abs (car p1))) 6));在6种图案中随机选择
  11.   (setq t1 (+ (*(rem (abs (+ (car p1) (cadr p1))) 1) 0.4) 0.6));大小在0.6~1.0之间随机选择
  12.   (setq m (+ 1 (rem (fix (* t1 n (abs (cadr p1)))) 255)));在255种颜色中随机选择
  13.   (command "color" m)
  14.   (cond ( (= 0 n)
  15.     (command "pline" p1 "w" 0.4 0.4 (polar p1 (/ pi 2) 5) "")
  16.     (setq p2 (polar p1 (/ pi 2) 1.8))
  17.     (setq p3 (polar p1 (/ pi 2) 3))
  18.     (command "pline" p2 (polar p2 (* 5 (/ pi 6)) 1.8) "")
  19.     (command "pline" p2 (polar p2 (/ pi 6) 1.8) "")
  20.     (command "pline" p3 (polar p3 (* 5 (/ pi 6)) 2) "")
  21.     (command "pline" p3 (polar p3 (/ pi 6) 2) "")
  22.     (command "arraypolar" (ssget "c" (polar p2 0 0.5) (polar p3 pi 0.5)) "" p1 6 360 "")
  23.     (command "scale" (ssget "c" (polar p1 (* -0.25 pi) 7.8) (polar p1 (* 0.75 pi) 7.8)) "" p1 t1)
  24.     )
  25.     ((= 1 n)
  26.     (command "pline" p1 "w" 0.4 0.4 (polar p1 (/ pi 2) 5) "")
  27.     (setq p2 (polar p1 (/ pi 2) 1.8))
  28.     (setq p3 (polar p1 (/ pi 2) 3))
  29.     (command "pline" p2 (polar p2 (* 5 (/ pi 6)) 1.3856) "")
  30.     (command "pline" p2 (polar p2 (/ pi 6) 1.3856) "")
  31.     (command "pline" p3 (polar p3 (* 5 (/ pi 6)) 1.3856) "")
  32.     (command "pline" p3 (polar p3 (/ pi 6) 1.3856) "")
  33.     (command "arraypolar" (ssget "c" (polar p2 0 0.5) (polar p3 pi 0.5)) "" p1 6 360 "")
  34.       (command "scale" (ssget "c" (polar p1 (* -0.25 pi) 7.8) (polar p1 (* 0.75 pi) 7.8)) "" p1 t1)
  35.     )
  36.     ((= 2 n)
  37.     (command "pline" p1 "w" 0.2 0.2 (polar p1 (/ pi 2) 5) "")
  38.     (setq p2 (polar p1 (/ pi 2) 1.6262))
  39.     (setq p3 (polar p1 (/ pi 2) 2.533))
  40.     (setq p4 (polar p1 (/ pi 2) 3.4549))
  41.     (setq p5 (polar p1 (/ pi 2) 4.3595))
  42.     (command "pline" p2 (polar p2 (* 3 (/ pi 4)) 1.6262) "")
  43.     (command "pline" p3 (polar p3 (* 3 (/ pi 4)) 1.2672) "")
  44.     (command "pline" p4 (polar p4 (* 3 (/ pi 4)) 0.9612) "")
  45.     (command "pline" p5 (polar p5 (* 3 (/ pi 4)) 0.6610) "")
  46.     (command "mirror" (ssget "c" (polar p2 pi 0.1) (polar p5 (* 3 (/ pi 4)) 0.6610)) "" p1 p5 "N")
  47.     (command "arraypolar" (ssget "c" (polar p2 0 0.5) (polar p5 (* 3 (/ pi 4)) 0.6610)) "" p1 8 360 "")
  48.       (command "scale" (ssget "c" (polar p1 (* -0.25 pi) 7.8) (polar p1 (* 0.75 pi) 7.8)) "" p1 t1)
  49.     )
  50.     ((= 3 n)
  51.     (command "pline" p1 "w" 0.2 0.2 (polar p1 (/ pi 2) 5.0621) "")
  52.     (setq p2 (polar p1 (/ pi 2) 1.6425))
  53.     (setq p3 (polar p1 (/ pi 2) 2.4152))
  54.     (setq p4 (polar p1 (/ pi 2) 4.0147))
  55.     (setq p5 (polar p3 (* pi 0.75) 1.9043))
  56.     (setq p6 (polar p3 (* pi 0.75) 1.0421))
  57.     (command "pline" p2 (polar p2 (* pi 1.25) 0.8502) "")
  58.     (command "pline" p3 p5 "")
  59.     (command "pline" p6 (polar p6 pi 0.8669) "")
  60.     (command "pline" p6 (polar p6 (/ pi 2) 0.8669) "")
  61.     (command "pline" p4 (polar p4 (* pi 0.75) 0.9244) "")
  62.     (command "mirror" (ssget "c" (polar p1 pi 0.1) (polar p5 (/ pi 2) 1)) "" p1 p4 "N")
  63.     (command "arraypolar" (ssget "c" (polar p1 0 1.5) (polar p5 (/ pi 2) 1)) "" p1 6 360 "")
  64.       (command "scale" (ssget "c" (polar p1 (* -0.25 pi) 7.8) (polar p1 (* 0.75 pi) 7.8)) "" p1 t1)
  65.     )
  66.     ((= 4 n)
  67.     (command "pline" p1 "w" 0.2 0.2 (polar p1 (/ pi 2) 5.3817) "")
  68.     (setq p2 (polar p1 (/ pi 2) 0.9731))
  69.     (setq p3 (polar p1 (/ pi 2) 2.1459))
  70.     (setq p4 (polar p1 (/ pi 2) 3.2399))
  71.     (setq p5 (polar p1 (/ pi 2) 4.3489))
  72.     (command "pline" p2 (polar p2 (* pi 0.75) 1.5141) "")
  73.     (command "pline" p3 (polar p3 (* pi 0.75) 1.5592) "")
  74.     (command "pline" p4 (polar p4 (* pi 0.75) 1.3053) "")
  75.     (command "pline" p5 (polar p5 (* pi 0.75) 0.8244) "")
  76.     (command "mirror" (ssget "c" (polar p1 pi 0.1) (polar p5 (* pi 0.75) 0.8244)) "" p1 p5 "N")
  77.     (command "arraypolar" (ssget "c" (polar p1 0 1) (polar p5 (* pi 0.75) 0.8244)) "" p1 6 360 "")
  78.       (command "scale" (ssget "c" (polar p1 (* -0.25 pi) 7.8) (polar p1 (* 0.75 pi) 7.8)) "" p1 t1)
  79.     )
  80.     ((= 5 n)
  81.     (command "pline" p1 "w" 0.2 0.2 (polar p1 (/ pi 2) 5.4448) "")
  82.     (setq p2 (polar p1 (/ pi 2) 1.6816))
  83.     (setq p3 (polar p1 (/ pi 2) 2.6329))
  84.     (setq p4 (polar p1 (/ pi 2) 3.5759))
  85.     (setq p5 (polar p1 (/ pi 2) 4.5340))
  86.     (command "pline" p2 (polar p2 (* pi (/ 136.0666 180)) 1.6184) "")
  87.     (command "pline" p3 (polar p3 (* pi (/ 136.0666 180)) 1.3206) "")
  88.     (command "pline" p4 (polar p4 (* pi (/ 136.0666 180)) 0.9725) "")
  89.     (command "pline" p5 (polar p5 (* pi (/ 136.0666 180)) 0.6660) "")
  90.     (command "mirror" (ssget "c" (polar p1 pi 0.1) (polar p5 (* pi (/ 136.0666 180)) 0.6660)) "" p1 p5 "N")
  91.     (command "arraypolar" (ssget "c" (polar p1 0 0.5) (polar p5 (* pi (/ 136.0666 180)) 0.6660)) "" p1 12 360 "")
  92.     (command "scale" (ssget "c" (polar p1 (* -0.25 pi) 7.8) (polar p1 (* 0.75 pi) 7.8)) "" p1 t1)
  93.     )
  94.   )
  95.
  96.   (setvar "osmode" v1)
  97.   (setvar "cmdecho" v2)
  98.   (setvar "blipmode" v3)
  99.   (princ)
  100. )
参与人数 4明经币 +4 收起 理由
USER2128 + 1 很给力!
baitang36 + 1 很给力!
VBALISPER + 1 赞一个!
xyp1964 + 1 赞一个!
发表于 2025-2-20 10:47:03 | 显示全部楼层
世界上没有相同的两片雪花
那就加上 random 函数,随机参数值生成雪花,应该蛮好玩的。  发表于 2025-2-20 11:41
那就加上 radrom 函数,随机参数值生成雪花,应该蛮好玩的。  发表于 2025-2-20 11:40
发表于 2025-2-20 11:54:02 | 显示全部楼层
有意思的工具,谢谢分享。
发表于 2025-2-21 07:49:27 来自手机 | 显示全部楼层
很棒!楼主对雪花形状很有研究!
发表于 2025-2-21 08:13:36 | 显示全部楼层
再从上往下落,左右随机移动,随机旋转角度。
 楼主| 发表于 2025-2-21 13:32:33 | 显示全部楼层
想法很好,但有点超出我的能力范围了
 楼主| 发表于 2025-2-21 13:34:02 | 显示全部楼层
Myday 发表于 2025-2-21 07:49
很棒!楼主对雪花形状很有研究!
网上查的图片,照着描的
 楼主| 发表于 2025-2-21 20:26:21 | 显示全部楼层
考虑代码的通用性,没有用这个生成随机数:
发表于 2025-2-23 14:56:22 | 显示全部楼层
挺有意思的,感谢分享
GMT+8, 2025-8-21 04:32 , Processed in 0.150361 second(s), 27 queries , Gzip On.
