- 积分
- 6052
- 明经币
- 个
- 注册时间
- 2016-10-12
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - using HTJ.Arx.Service.Imp;
- namespace HTJ.Arx;
- public static class EditEx
- /// <summary>
- /// 以单点(中心点)构造选择点集
- /// </summary>
- /// <param name="cenpt">中心单点3D</param>
- /// <param name="ex">偏移量</param>
- /// <returns>点集合</returns>
- public static Point3dCollection GetPointCollection(this Point3d cenpt, double ex = 1e-3)
- return new Point3dCollection
- new Point3d(cenpt.X - 0.5 * ex, cenpt.Y - 0.5 * ex, 0),
- new Point3d(cenpt.X + 0.5 * ex, cenpt.Y - 0.5 * ex, 0),
- new Point3d(cenpt.X + 0.5 * ex, cenpt.Y + 0.5 * ex, 0),
- new Point3d(cenpt.X - 0.5 * ex, cenpt.Y + 0.5 * ex, 0)
- /// <summary>
- /// </summary>
- /// <param name="cenpt">中心单点2D</param>
- public static Point3dCollection GetPointCollection(this Point2d cenpt, double ex = 1e-3)
- return GetPointCollection(cenpt.Point3d(), ex);
- /// <summary>
- /// 单点(左下角)构造选择点集
- /// </summary>
- /// <param name="minpt">二维点</param>
- /// <param name="width">宽度</param>
- /// <param name="height">高度</param>
- /// <returns>四个角点组成的点集</returns>
- public static Point3dCollection GetPointCollection(this Point2d minpt, double width, double height)
- new Point3d(minpt.X, minpt.Y, 0),
- new Point3d(minpt.X + width, minpt.Y, 0),
- new Point3d(minpt.X + width, minpt.Y + height, 0),
- new Point3d(minpt.X, minpt.Y + height, 0)
- /// <summary>
- /// 单点(左下角)构造选择点集
- /// </summary>
- /// <param name="minPt">三维点</param>
- public static Point3dCollection GetPointCollection(this Point3d minPt, double width, double height)
- var pt2d = new Point2d(minPt.X, minPt.Y);
- return GetPointCollection(pt2d, width, height);
- /// <summary>
- /// 两点构造选择点集
- /// </summary>
- /// <param name="ptA">三维点</param>
- /// <param name="ptB">三维点</param>
- /// <param name="ex">外扩距离</param>
- public static Point3dCollection GetPointCollection(this Point3d ptA, Point3d ptB, double ex = 1e-3)
- var minX = Math.Min(ptA.X, ptB.X) - ex;
- var minY = Math.Min(ptA.Y, ptB.Y) - ex;
- var maxX = Math.Max(ptA.X, ptB.X) + ex;
- var maxY = Math.Max(ptA.Y, ptB.Y) + ex;
- new Point3d(minX, minY, 0),
- new Point3d(maxX, minY, 0),
- new Point3d(maxX, maxY, 0),
- new Point3d(minX, maxY, 0)
- /// <summary>
- /// 两点构造选择点集
- /// </summary>
- /// <param name="ptA">二维点</param>
- /// <param name="ptB">二维点</param>
- public static Point3dCollection GetPointCollection(this Point2d ptA, Point2d ptB, double ex = 1e-3)
- return ptA.Point3d().GetPointCollection(ptB.Point3d(), ex);
- /// <summary>
- /// 外包构造选择点集
- /// </summary>
- /// <param name="box"></param>
- /// <param name="ex"></param>
- /// <returns></returns>
- public static Point3dCollection GetPointCollection(this BoundingInfo box, double ex = 1e-3)
- var ext3d = box.Extents3d;
- var pt1 = ext3d.MinPoint;
- var pt2 = ext3d.MaxPoint;
- return pt1.GetPointCollection(pt2, ex);
- /// <summary>
- /// 外包构造选择点集
- /// </summary>
- /// <param name="ext3d"></param>
- public static Point3dCollection GetPointCollection(this Extents3d ext3d, double ex = 1e-3)
- /// <summary>
- /// Rect造选择点集
- /// </summary>
- /// <param name="rect"></param>
- public static Point3dCollection GetPointCollection(this Rect rect, double ex = 1e-3)
- return rect.MinPoint.GetPointCollection(rect.MaxPoint, ex);
- public static Point3dCollection GetPointCollection(this RectAngEx.RectAng rectAng, double ex = 1e-3)
- var newRectAng = rectAng.Expand(ex);
- var pts = newRectAng.ToPoints();
- var nptc = new Point3dCollection();
- for (var i = pts.Length - 1; i >= 0; i--)
- var pt = pts[i].Point3d();
- nptc.Add(pt);
- return nptc;
- /// <summary>
- /// 获取矩阵变换(平移,缩放,旋转)后的点集
- /// </summary>
- /// <param name="ptColl">原始点集</param>
- /// <param name="mat">矩阵变量</param>
- /// <returns>返回变换后的点集</returns>
- public static Point3dCollection TransformBy(this Point3dCollection ptColl, Matrix3d mat)
- for (var i = ptColl.Count - 1; i >= 0; i--)
- var pt = ptColl[i].TransformBy(mat);
- nptc.Add(pt);
- return nptc;
- /// <summary>
- /// 获取一个字符串
- /// </summary>
- /// <param name="ed"></param>
- /// <param name="str"></param>
- /// <param name="msg"></param>
- public static bool GetString(this Editor ed, out string str, string msg = "输入一个字符串:<空格退出>")
- str = string.Empty;
- var pso = new PromptStringOptions(Environment.NewLine + msg)
- AllowSpaces = true //允许空格
- var pdr = ed.GetString(pso);
- if (pdr.Status != PromptStatus.OK)
- return false;
- str = pdr.StringResult;
- return true;
- /// <summary>
- /// 获取一个实数
- /// </summary>
- /// <param name="value"></param>
- public static bool GetDouble(this Editor ed, out double value, string msg = "输入一个实数:<空格退出>")
- value = 0.0;
- var pdo = new PromptDoubleOptions(Environment.NewLine + msg)
- AllowArbitraryInput = true, //任意输入
- AllowNone = true //允许回车
- var pdr = ed.GetDouble(pdo);
- return false;
- value = pdr.Value;
- return true;
- /// <summary>
- /// 获取下一个点
- /// </summary>
- /// <param name="ed">命令行</param>
- /// <param name="pt">获取的点</param>
- /// <param name="msg">提示</param>
- public static bool GetPoint(this Editor ed, out Point3d pt, string msg = "指定一点:<空格退出>")
- pt = new Point3d();
- var ppo = new PromptPointOptions(Environment.NewLine + msg)
- var ppr = ed.GetPoint(ppo);
- if (ppr.Status != PromptStatus.OK)
- return false;
- pt = ppr.Value;
- return true;
- /// <summary>
- /// 获取下一个点
- /// </summary>
- /// <param name="ptk">上一个点</param>
- public static bool GetPoint(this Editor ed, out Point3d pt, Point3d ptk, string msg = "指定一点:<空格退出>")
- var ppr = ed.GetPoint(msg, ptk);
- return false;
- pt = ppr.Value;
- return true;
- /// <summary>
- /// 屏幕拾取实体列表
- /// </summary>
- /// <typeparam name="T">实体类型</typeparam>
- /// <param name="ents">指定类型的List</param>
- /// <param name="fil">过滤条件,为空时候无条件</param>
- /// <returns>bool</returns>
- public static bool GetEnts<T>(this Editor ed,
- out List<T> ents,
- SelectionFilter? fil = null,
- string msg = "请选择对象:") where T : Entity
- ents = new List<T>();
- var pso = new PromptSelectionOptions
- MessageForAdding = Environment.NewLine + msg
- var psr = ed.GetSelection(pso, fil);
- if (psr.Status != PromptStatus.OK)
- return false;
- ents = psr.Value.GetEntities<T>().ToList();
- return ents.Any();
- /// <summary>
- /// 窗选模式获取取实体列表
- /// </summary>
- /// <param name="ptColl">点集合,为空时候全选模式</param>
- public static bool SelEnts<T>(this Editor ed,
- out List<T> ents,
- Point3dCollection? ptColl = null,
- SelectionFilter? fil = null) where T : Entity
- var psr = ptColl != null ? ed.SelectCrossingPolygon(ptColl, fil) : ed.SelectAll(fil);
- return false;
- return ents.Count>0;
- /// <summary>
- /// 点选获取单个实体
- /// </summary>
- /// <param name="t">实体</param>
- /// <param name="pt">返回点</param>
- /// <param name="isNested">块内</param>
- public static bool SelEnt<T>(this Editor ed,
- out T t,
- out Point3d pt,
- bool isNested = false,
- t = null!;
- ObjectId id;
- if (isNested)
- var pner = ed.GetNestedEntity(Environment.NewLine + msg);
- pt = pner.PickedPoint;
- if (pner.Status != PromptStatus.OK)
- return false;
- id = pner.ObjectId;
- else
- var per = ed.GetEntity(Environment.NewLine + msg);
- pt = per.PickedPoint;
- if (per.Status != PromptStatus.OK)
- return false;
- id = per.ObjectId;
- if (id.GetObject<Entity>() is not T result)
- return false;
- t = result;
- return true;
- /// <summary>
- /// 点选获取单个实体
- /// </summary>
- out T t,
- where T : Entity
- t = null!;
- ObjectId id;
- if (isNested)
- return false;
- else
- return false;
- if (id.GetObject<T>() is not { } result)
- return false;
- t = result;
- return true;
- /// <summary>
- /// 点选获取单个实体Id
- /// </summary>
- /// <param name="id"></param>
- /// <param name="tClass">RXClass类型</param>
- public static bool SelId(this Editor ed,
- out ObjectId id,
- out Point3d pt,
- RXClass? tClass = null,
- id = ObjectId.Null;
- if (isNested)
- return false;
- else
- if (per.Status != PromptStatus.OK) return false;
- return tClass == null || id.IsDerivedFrom(tClass);
- /// <summary>
- /// 点选获取单个实体Id
- /// </summary>
- out ObjectId id,
- if (isNested)
- if (pner.Status != PromptStatus.OK) return false;
- else
- /// <summary>
- /// 窗选模式获取取实体列表
- /// </summary>
- /// <param name="ids">指定类型的List</param>
- /// <param name="ptc">点集合,为空时候全选模式</param>
- public static bool SelIds(this Editor ed,
- out List<ObjectId> ids,
- Point3dCollection? ptc = null,
- var psr = ptc != null ? ed.SelectCrossingPolygon(ptc, fil) : ed.SelectAll(fil);
- ids = new List<ObjectId>();
- return false;
- ids = psr.Value.GetObjectIds().ToList();
- if (tClass != null)
- ids = ids.Where(id => id.IsDerivedFrom(tClass)).ToList();
- return ids.Count>0;
