查看: 1347|回复: 5
【悬赏5明经币求程序】求"左下角插入基准图块"的lisp
发表于 2025-2-13 21:31:10 | 显示全部楼层 |阅读模式
5明经币
请求哪位大师帮忙写一个  lisp程序
1 选择直线和多段线
2 相交直线计算交点,在交点插入图块21-jzcor00vvv
3 多段线计算包围盒边界左下角dian,inx和miny,插入图块21-jzcor00vvv
  注意附件的多段线一般都是封闭矩形
要求能一次选多个直线和多段线
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
小可并非大师,一个爱好者而已。 下面这个文件,将(command)调用转换为(command-s),再试试看吧。
发表于 2025-2-13 21:31:11 | 显示全部楼层
ninja37 发表于 2025-2-17 18:35
煮茗大师,实在不好意思,是autocad2023,出现以下错误。
命令: LHTUKJZCOR00YUANINT1
★ 功能:批量模板 ...
小可并非大师,一个爱好者而已。
 楼主| 发表于 2025-2-15 11:18:46 | 显示全部楼层
(defun ssinters        (ss / i num obj1 obj2 j interpts ptlist)
  (setq        i   0
                num (sslength ss)
  (while (< i (1- num))
    (setq obj1 (ssname ss i)
                        obj1 (vlax-ename->vla-object obj1)
                        j    (1+ i)
    (while (< j num)
      (setq obj2     (ssname ss j)
                                obj2     (vlax-ename->vla-object obj2)
                                interpts (vla-intersectwith
        obj1
        obj2
        0
                                interpts (vlax-variant-value interpts)
      (if (> (vlax-safearray-get-u-bound interpts 1) 0)
          (setq        interpts
                                                (vlax-safearray->list interpts)
          (while (> (length interpts) 0)
            (setq ptlist (cons (list (car interpts)
        (cadr interpts)
        (caddr interpts)
        ptlist
            (setq interpts (cdddr interpts))
      (setq j (1+ j))
    (setq i (1+ i))
  ptlist
(defun cHTUKJZCOR00YUANINT1 ()
  (setvar "cmdecho" 0)
        (setvar "osmode" 0) (setvar "orthomode" 0) (command "UCS"  "W")
        (command "layer" "on" "40" "")
        (setvar "clayer" "1")
  (vl-load-com)
        (setvar "osmode" 0)
        ;;;(setvar "osmode" 15359)
  (princ "\n★ 功能:批量模板基准角插入   (碰数点+基准)  ")
  (princ "\n★ 请选择两条相交的直线   (可以多选 批量选择)(非多段线):")
  (command "undo" "be")
;;;        (if (not (setq ss (ssget '((0 . "*LINE,ARC,CIRCLE,ELLIPSE")))))
  (if (not (setq ss (ssget '((0 . "*LINE,LWPOLYLINE")))))
    (progn (princ "\n提示:未选取图元,程序退出。\n") (exit))
;;;        (command "explode" ss)
  (setq acad (vlax-get-acad-object))
  (setq acaddocument (vla-get-activedocument acad))
  (setq mspace (vla-get-modelspace acaddocument))
        ;;;          (setq blockname (cdr (assoc 2 (entget blockentname))))
        ;;;   (setq blockentname  "LHCENPOINT1")
        (setq blockname  "21-jzcor03YUAN")
        (setq bili 1.0)
        (initget 6)
  (setvar "osmode" 0)
  (setq ptlist (ssinters ss))
  (foreach pt ptlist
                ;;;(command "_insert" "LHCENPOINT1"  (vlax-3d-point ptlist) "1" "1" "1" "0")
                (vla-insertblock mspace  (vlax-3d-point pt)  "21-jzcor00VVV.dwg" 1 1 1 0)
  (command "undo" "e")
        (setvar "osmode" 0)
        (setvar "cmdecho" 1)
        ;;;  (setvar "osmode" 15359)
)这个程序是目前在用的  选择相交直线   可以在交点插入图块
发表于 2025-2-16 10:41:08 | 显示全部楼层
说明:根据你提供的代码修改的。
思路是:把选择集进行筛分,如果是多段线,获取其包围框左下角点,插入图块;如果是直线,进行交点分析,获取交点插入图块。
 楼主| 发表于 2025-2-17 18:35:52 | 显示全部楼层
选择对象: 指定对角点: 找到 1 个
选择对象:
调用(*push-error-using-command*)前无法从 *error* 调用(command)。
建议将(command)调用转换为(command-s)。
 楼主| 发表于 2025-3-14 21:23:37 | 显示全部楼层
煮茗 发表于 2025-2-16 10:41
说明:根据你提供的代码修改的。
思路是:把选择集进行筛分,如果是多段线,获取其包围框左下角 ...
谢谢大师帮忙,这个现在用起来很好
GMT+8, 2025-5-1 04:27 , Processed in 0.150420 second(s), 23 queries , Gzip On.
