帖子
查看: 1499|回复: 3
切换快捷键图层时检查图层是否存在,如果不存在则按给定的图层颜色、线型等创建相...
发表于 2025-1-17 16:26:22 | 显示全部楼层 |阅读模式
;;;;;;;;切换图层时检查图层是否存在,如果不存在则按给定的图层颜色、线型等创建相应图层
(defun create-layer-if-not-exists (layer-name color linetype)
  (if (not (tblsearch "LAYER" layer-name))
      (entmake (list
                 (cons 0 "LAYER")
  1. ;;;;;;;;切换图层时检查图层是否存在,如果不存在则按给定的图层颜色、线型等创建相应图层
  2. (defun create-layer-if-not-exists (layer-name color linetype)
  3.   (if (not (tblsearch "LAYER" layer-name))
  4.     (progn
  5.       (entmake (list
  6.                  (cons 0 "LAYER")
  7.                  (cons 100 "AcDbSymbolTableRecord")
  8.                  (cons 100 "AcDbLayerTableRecord")
  9.                  (cons 2 layer-name)
  10.                  (cons 70 0)
  11.                  (cons 62 color)
  12.                  (cons 6 linetype)
  13.                ))
  14.       (princ (strcat "\n图层 " layer-name " 已创建。"))
  15.     )
  16.   )
  17. )
  18. (defun set-layer (layer-name color linetype)
  19.   (create-layer-if-not-exists layer-name color linetype)
  20.   (setvar "clayer" layer-name)
  21.   (princ (strcat "\n已经切换到:" layer-name))
  22. )
  23. (defun c:F1 () (set-layer "A-ELEV-LIN1-立面外轮廓线" 42 "Continuous"))
  24. (defun c:F2 () (set-layer "A-ELEV-LIN2-立面中轮廓线" 2 "Continuous"))
  25. (defun c:F3 () (set-layer "A-ELEV-LIN3-立面细轮廓线" 153 "Continuous"))
  26. (defun c:F4 () (set-layer "A-FURN-绘图层" 2 "Continuous"))
  27. (defun c:F5 () (set-layer "0-PM-固定家具" 251 "Continuous"))
  28. (defun c:F6 () (set-layer "Area【区域轮廓不打印】" 250 "Continuous"))
  29. (defun c:FFC () (set-layer "DOTE" 1 "dote"))
  30. (defun c:FFD () (set-layer "DOOR" 4 "Continuous"))
  31. (defun c:FFDD () (set-layer "DOOR-NAME" 4 "Continuous"))
  32. (defun c:FFW () (set-layer "WINDOW" 4 "Continuous"))
  33. (defun c:FFWW () (set-layer "WINDOW_TEXT" 4 "Continuous"))
  34. (defun c:FW () (set-layer "WALL" 42 "Continuous"))
  35. (defun c:FFX () (set-layer "0-PM-建筑面积计算" 5 "Continuous"))
  36. (defun c:D1 () (set-layer "0-DM-地面填充" 251 "Continuous"))
  37. (defun c:D2 () (set-layer "0-DM-地面尺寸标注" 3 "Continuous"))
  38. (defun c:D3 () (set-layer "0-DM-地坪分割线" 251 "Continuous"))
  39. (defun c:T1 () (set-layer "0-TF-天花布置" 251 "Continuous"))
  40. (defun c:T2 () (set-layer "0-TF-天花尺寸标注" 3 "Continuous"))
  41. (defun c:T3 () (set-layer "0-TF-天花灯具布置" 6 "Continuous"))
                 (cons 2 layer-name)
                 (cons 70 0)
                 (cons 62 color)
                 (cons 6 linetype)
发表于 2025-1-18 07:33:15 | 显示全部楼层
收藏了!有一天可能会用到
发表于 2025-1-18 09:44:57 | 显示全部楼层
谢谢楼主分享,很不错!!!
GMT+8, 2025-6-6 23:52 , Processed in 0.187344 second(s), 22 queries , Gzip On.
