- 积分
- 28232
- 明经币
- 个
- 注册时间
- 2007-4-24
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
测试1
采集点 100000 个
最近点对距离 = 0.312
分治算法求解最近点对用时: 31 毫秒
测试2
采集点 157011 个
最近点对距离 = 0.028
分治算法求解最近点对用时: 46 毫秒
测试3
采集点 1436160 个
最近点对距离 = 0.003
分治算法求解最近点对用时: 1828 毫秒
- // 归并排序的归并操作(对y排序)
- static void Merge(AcGePoint3dArray &pts, int nLeft, int nRight)
- int mid = (nLeft + nRight) / 2;
- int i = nLeft;
- int j = mid + 1;
- AcGePoint3dArray resPts;
- while (i <= mid && j <= nRight)
- if (pts.at(i).y < pts.at(j).y)
- resPts.append(pts.at(i++));
- else
- resPts.append(pts.at(j++));
- while (i <= mid)
- while (j <= nRight)
- for (int i = nLeft; i < resPts.length(); i++)
- pts.at(i) = resPts.at(i);
复制代码- // 计算点对距离
- static double distance(const AcGePoint3d& p1, const AcGePoint3d& p2)
- return sqrt((p1.x - p2.x) * (p1.x - p2.x) + (p1.y - p2.y) * (p1.y - p2.y));
复制代码- // 分治法找最近点对
- static double mergeMethod(AcGePoint3dArray &pts, int nLeft, int nRight, AcGePoint3d &p1, AcGePoint3d &p2)
- if (nRight - nLeft <= 1)
- return INT_MAX;
- else if (nRight - nLeft == 2)
- Merge(pts, nLeft, nRight);//确保每个小单元的两个点对的y轴是有序的,才能保证后续对y归并排序的复杂度
- p1 = pts.at(nLeft);
- p2 = pts.at(nRight);
- return distance(p1, p2);
- else
- AcGePoint3d l1, l2, r1, r2;
- double mindis = INT_MAX;
- double middleX = pts.at(mid).x; //中线
- double mindis1 = mergeMethod(pts, nLeft, mid, l1, l2); // 左侧最近点对
- double mindis2 = mergeMethod(pts, mid + 1, nRight, r1, r2); // 右侧最近点对
- if (mindis1 < mindis2)
- mindis = mindis1;
- p1 = l1;
- p2 = l2;
- else
- mindis = mindis2;
- p1 = r1;
- p2 = r2;
- AcGePoint3dArray temp;
- Merge(pts, nLeft, nRight); // 按照y排序
- for (int i = nLeft; i <= nRight; i++) //找到在中间区域的点
- if (fabs(pts.at(i).x - middleX) <= mindis)
- temp.append(pts.at(i));
- double tempDis = INT_MAX;
- // 遍历中间数组,每个点最多遍历其他点6次,记录最短距离和点对
- for (int i = 0; i < temp.length(); i++)
- for (int j = i + 1; j < i + 1 + 6 && j < temp.length(); j++)
- tempDis = distance(temp[i], temp[j]);
- if (tempDis < mindis)
- mindis = tempDis;
- p1 = temp[i];
- p2 = temp[j];
- return mindis;
复制代码
